tachometer malfunction
08.05.2020 17:05 # 1
durucuk
hello friends 307 when the car is in progress, the tacho clock reduces itself to zero and the car gives a stop warning but the car is not working any problem, just because the tacho clock falls to that zero, the car warning data will cause the stop flashing. the clock is getting better
08.05.2020 17:05 # 2
Psh
I survived the same event more freshly. It started with the tachometer first. You can find the story and solution of the problem in the link below. & Nbsp;
08.05.2020 17:05 # 3
durucuk
thank you so much thanks
08.05.2020 17:05 # 4
durucuk
I will tell you what happened to me, my master, I went to the authorized service, they connected the car to the computer and the left rear abs sensor was broken, he said, he changed it, then he said that he had not repaired that he was repairing the charger, I did not change it, I came to the electrician, and if I changed the conch, I would change the dynamo, if I leave it to the service, I was burned and the problem was solved. literally, you have a kneader with
08.05.2020 17:05 # 5
Psh
I am completely in trouble.
08.05.2020 17:05 # 6
DeAtHeR
307 SW 1.6 Pack Gasoline + LPG
The same thing started with me, so first thing is & nbsp; alternator if we don't change the connector bi :)
Eyev`ALLAH
