tachometer failure help
08.05.2020 16:24 # 1
mon
friends, easy to everyone. Until just 2 weeks ago, my hard-working tachometer now shows false values. it works, but sometimes it shows 100 RPM and sometimes 2000 RPM when idling, I can hear the needle change by click, I wonder where the problem is? the needle stays just as soon as the ignition is turned off. When the ignition is turned on and off, it falls a little and it turns to a few times when it turns on.
08.05.2020 16:24 # 2
06OzGuR06
There may be a malfunction of the speed sensor. You can connect the vehicle to the computer and see the malfunction.
08.05.2020 16:24 # 3
06OzGuR06
Does the indicator on the display show correct, except the tachometer?
08.05.2020 16:24 # 4
mon
[QUOTE = 06EZGÜR06] Does the indicator on the indicator show correctly, except for the tachometer?
my km indicator occasionally gets stuck, other gauges have no problem.
08.05.2020 16:24 # 5
This is a very common situation in the 206's. With the Peugeot Planet 2000 system, it can be checked whether the fault is electronic or not. Other cases indicate a malfunction in the instrument cluster. Reviews
08.05.2020 16:24 # 6
06OzGuR06
If there is no problem with the speed and km sensor after connecting and looking at the computer, your combi indicator is defective.
08.05.2020 16:24 # 7
mon
When you say combi indicator?
08.05.2020 16:24 # 8
06OzGuR06
When saying [QUOTE = mon] boiler indicator? [/ QUOTE]
I mean the dashboard.
