tachometer
08.05.2020 17:49 # 1
mustafasevik
friends, the clock is below zero, when the vehicle is not working, I removed the pole head.
08.05.2020 17:49 # 2
burakkaya
the same problem happened to me on the speedometer today. When I turned the ignition to start my car's battery was discharged, a click sound came and the indicators were moving below zero and the car was not working. then somehow we started the car and brought it to the front of the house. but I saw that the speedometer went below zero. How to fix this problem When I replace the battery, does the problem go away? My car is 206 hdi x-design 2005 model.
08.05.2020 17:49 # 3
zerzevat
the subject is old but maybe it will be useful to someone who is calling.
Remove the hat on the indicator by pulling / prying towards the steering wheel. First of all, it will be useful to start from the part close to the steering part.
then you removed it carefully without breaking the gauge glass. Meanwhile, the km reset button is causing some trouble.
then turn the ignition on and off once, or keep the parking lights on so that the indicators are powered on or the hands are not idle. Then, slowly remove the needle, which shows the wrong hand, with the support of the ground with the fingernails of both hands. plug back into the position where it should stop. I think it was a little under 10 km for km.
It happened to me very often in cold weather because my battery is weak. constantly threw back. I finally end up with a barrier that I made with double-sided tape. I glued the needle so as not to throw it back. he's striking the brainer. can't throw it backwards.
The exact solution, km mechanic is changing his engine for 100 lira.
08.05.2020 17:49 # 4
erdemchetin
The same problem existed with me, the era fell below zero and then progressed to 30 while saying 60-50-40. Let's try it, let's see if we are going to go to the repair shop, or even make videos while we are doing, maybe it will help.
