Tachometer
08.05.2020 21:01 # 1
selccukk
Hello friends 206 1.6 xt gasoline tachometer of my car broke down is not moving how can I complete it?
08.05.2020 21:01 # 2
bilo131
The topic of repair is illustrated in the forum.
I think you reside in Bolu. I live in Düzce, if you can't, I will help. I had 2 206 vehicles, 2 of them, the tachometer was defective.
08.05.2020 21:01 # 3
selccukk
Master, I'm in Ankara right now.
08.05.2020 21:01 # 4
Karacocuk24
[QUOTE = bilo131] The topic of repair is illustrated in the forum.
[/ QUOTE] today my speed dial is dust to 0 but my odometer is working.
08.05.2020 21:01 # 5
bilo131
[QUOTE = Karacocuk24] [QUOTE = bilo131] The subject of repair is illustrated in the forum.
[/ QUOTE] today my speed dial is dust to 0 but my odometer is working will this benefit my information [/ QUOTE]
Of course the same is already. If the pin holding the gear was broken when you disassembled the engine, you can handle your problem with this application. If it is solid, there is a different problem.
08.05.2020 21:01 # 6
Karacocuk24
[QUOTE = bilo131] [QUOTE = Karacocuk24] [QUOTE = bilo131] The subject of repair is illustrated in the forum.
[/ QUOTE] km counter is running speed indicator goes up and click it as if it is not enough power is coming back.
08.05.2020 21:01 # 7
talip206
Guys, let me remind you that there is only one detail. There are two types of indicators. In one, the km zeroing bar becomes one. In the other indicator type, there are both the zero reset bar and the bar on the left that adjusts the brightness of the screen.
On the indicator with a single bar, as the friend mentioned, the plastic holding the wheel is broken there.
There is no wheel in the other two-gauge display variant. Instead, they put a motor directly. It does not easily malfunction, it hangs. If you have a two-bar display, simply remove the glass and play it with your hand, a few to the left without removing it completely.
08.05.2020 21:01 # 8
Karacocuk24
I added it to my subject, my teacher, stay here https://youtu.be/MHdX1q4B-J8
08.05.2020 21:01 # 9
talip206
[QUOTE = Karacocuk24] I added my teacher to the topic I took, stay here https://youtu.be/MHdX1q4B-J8
Yes, for example, the indicator in this video has only one bar. As the friend bilo131 says, the plastic that holds the wheel is usually broken. But those with double rods do not have a wheel. For example double bar in the link below.
https://www.peugeotmarket.com/peugeot-206-gosterge-panelı-komple-orjınal,pr-850.html
talip206 2018-09-15 23:02:20
08.05.2020 21:01 # 10
bilo131
[QUOTE = talip206] [QUOTE = Karacocuk24] I added my teacher to the subject I stayed here, stay here https://youtu.be/MHdX1q4B-J8
I never knew the double stick thing. All of the vehicles in me were single Rods. Thank you for the information.
08.05.2020 21:01 # 11
talip206
[QUOTE = bilo131] [QUOTE = talip206] [QUOTE = Karacocuk24] I added my teacher to the topic I acted here, stay here https://youtu.be/MHdX1q4B-J8
There was an indicator malfunction in my vehicle. I removed the indicator to watch the videos and fix the wheel from the forum and the Internet. I had noticed the event then.
