System Too Lean?
08.05.2020 20:15 # 1
whisky
Anti in my car before. poll. I had the error because of the lpg, then I turned off the engine lamp with the obd2 device, it was not lit for about 2 months, but yesterday the vehicle was working on the first gasoline, it was still lit, when I look at it from the obd2 system too lean bank 1 warning, I think the oxygen is too low, the oxygen in the first engine Although I deleted the error in the sensor again, it repeats again, whether it is due to the poor mixture or if it might cause another problem, it was 2 days.
08.05.2020 20:15 # 2
GokhaN
As you said a problem with the air flow, the oxygen sensor from the poor mixture may sound simple and it may be useful to replace the air filter. There may be a leakage of fuel somewhere, it needs to be fully controlled, it is difficult to say something exactly
08.05.2020 20:15 # 3
Furkan979
If you delete it and it comes back again, there is a problem. Furkan979 2017-03-21 23:33:47
