Switching the air conditioner on and off ??
08.05.2020 15:15 # 1
bodrum7
Friends, when I run the air conditioner in my 2006 model gasoline 1.4 90 hp 207 car, the air conditioner is activated with a click sound of 10-15 seconds. They said that the air conditioner gas is missing or too much. What could be the reason, the special service compressor said it was faulty, but it doesn't seem to me either as if there is a leak in the air conditioner pipe or if there is a relay that enables the air conditioner to come on and off, it seems like there may be a problem in it. I would be glad if you could help.
In another question, can I open the aux input of my vehicle from the service and make an ipod or usb connection?
08.05.2020 15:15 # 2
A sound like this?
[TUBE] kp8pxmlfq_w [/ TUBE]
08.05.2020 15:15 # 3
Okay, anyway, the click sound is heard by the compressor clutch hold or release. There is a switch on the gas pipe of the air conditioner. They say prostate. this will make the air conditioner work. it may be necessary to connect it to a computer. Because it can be connected to the air conditioners of some vehicles ...
many fans come on when the air conditioner is turned on ??? Did you check? At one point, my roles were a problem. As the fans did not work, just as you said, the air conditioner started to shut down ... I wonder if the fan is not working for you to protect yourself.
08.05.2020 15:15 # 4
bodrum7
Like the sound in the video, this is the sound of the air conditioner coming in and out. What do you mean when you say fans? The air conditioner gives cold air if you mean it. But it comes in and out constantly.
08.05.2020 15:15 # 5
metin
The fan said by Cem brother must be the fan in the air conditioner radiator.
08.05.2020 15:15 # 6
bodrum7
I do not know that fan exactly.
08.05.2020 15:15 # 7
My brother, which fan will I be talking about, the only fan standing in front of the radiators ... :))
08.05.2020 15:15 # 8
In my old car, the air conditioner came into play and took it off. It could be understood from the unchanged rölartisi or the traction decreased. But I didn't think it was a malfunction. Refrigerator logic; I thought that he worked for a while and rested for a while. Testing in my new vehicle was not fortunate. Let's see if the summer will come in this?
08.05.2020 15:15 # 9
[QUOTE = badires] In my old car, the air conditioner is activated, deactivated. It could be understood from the unchanged rölartisi or the traction decreased. But I didn't think it was a malfunction. Refrigerator logic; I thought that he worked for a while and rested for a while. Testing in my new vehicle was not fortunate. Let's see if the summer will come in this? [/ QUOTE]
Now, if you press the gas moment, it can be deactivated or it may be deactivated sometimes due to the working principle.
But the person working at the meeting does not cease to come and go. the problem of the friend is that :))
something normal you're talking about. gas the moment while working at idle. In order not to force the engine, it turns off instantly and clicks on the idler, it clicks spontaneously, it activates ... I do not leave it longitudinal in all the vehicles, but generally it makes sense to disable it when the moment is necessary ...
08.05.2020 15:15 # 10
bodrum7
In my car, while it is on the relay, the air conditioner comes on and goes on, the cem is running on the fan you call it. I hope I'm going to a air conditioner and they hope it will be done. I don't think there is a malfunction in the air conditioner compressor, it seems to me that there is something in the relay.
08.05.2020 15:15 # 11
I don't have a situation that will turn it on or off in your role, but let me see what will come out ...
How long do you have electronic equipment in your vehicle? maybe an electronic failure. Let us share in this matter when it reaches the conclusion. I hope it is something :))
the cecol 2011-04-11 20:50:44
08.05.2020 15:15 # 12
bodrum7
thanks cem for your help, let's show hope it is simple.
08.05.2020 15:15 # 13
cagdasi
If your problem has reached a result, I would be glad if you give information.
Let me ask here not to open a new topic; If the outside temperature is lower than the one set in the air conditioner, does the air conditioner cool even in the air conditioner?
08.05.2020 15:15 # 14
esstel
I had the same problem in the video.
08.05.2020 15:15 # 15
mkaramese
the subject is beautifully hosed :) Mr. Esstel, the mentioned click sound is heard in me and it is contracting without a motor. I think the end of the question I mentioned in the http://forum.peugeotturkey.com/forum_posts.asp?TID=42650&title=partner-ilk-calisma-sor link will be linked here :) follow me :)
08.05.2020 15:15 # 16
esstel
Friends, I ask you to make the ones who have 1.4 hdi without makeup, run the air conditioner at idle .. Does the compressor come on and go out? or I am waiting for the comments of those who know about this subject ..
08.05.2020 15:15 # 17
madblueblacksea
Sometimes it will be in my vehicle if it is going to relax, but I forgot what it means. When the front of the car stayed in the sun and the radiator gave up, it cooled it with the fan and then the compressor was running. The idling doesn't seem to have much cooling anyway. I did not care because there is no problem while looking and I still do not care :)
08.05.2020 15:15 # 18
esstel
tşk. Some say it is normal that the compressor stops when the speed of the car rises. we have limited possibilities.It is necessary to clarify this situation ... either all peugeots or there is a problem in my vehicle ...
08.05.2020 15:15 # 19
alierdal0335
In a similar problem, if the fan I have experienced does not start, the vehicle does not operate the air conditioner automatically. Operate the air conditioner with hood open if the fan is not running, the problem is caused by the fan.
08.05.2020 15:15 # 20
esstel
The air conditioner is turned on, while the fan is waiting while idling, the fan comes on and turns out ... when I wonder and open the hood, the compressor comes on. It is the same video on the ground.
Page : / 2
