Switching from psx24w fog light to H11 fog light
08.05.2020 20:56 # 1
ELECTROMER
Greetings to all. My car is a 1.6 VTI 2011 model and has a silly fog lamp called Psx24w. I want to replace this with a fog lamp with H11 socket. If we come to my questions;
1) Has anyone done this process before? Is something like this possible?
2) Will it be a problem if I wear 55w halogen or 35w led after switching to the original fog lamp 24w and H11? So it's like flashing or not burning at all.
Thanks in advance.
08.05.2020 20:56 # 2
samet2461
There are led bulbs in the psx24w socket. It can be taken and put on. Why do you want to switch to H11?
08.05.2020 20:56 # 3
ELECTROMER
[QUOTE = samet2461] psx24w socket has led bulbs. It can be taken and put on. Why do you want to switch to H11? [/ QUOTE]
Hodja, I found a few psx24w socket leds, but under the advertisement it was said that it does not fit peugeot vehicles due to the size of the led.
see;
If you have a led suggestion suitable for your psx24w socket, I can get it.
08.05.2020 20:56 # 4
samet2461
As far as I know, ğsx24w is passing through H16. However, a short led lamp is required for fog. There is Aliexpresste but I don't think it will give very bright light. Is the short between the socket and the glass normal led can not fit?
08.05.2020 20:56 # 5
ELECTROMER
Yes, my teacher is short between the glass and the nest. I also read from some forums that you can wear the old fog light H11 of 207, but I was not sure. If the H11 fog light is suitable, there is no problem because there are lots of LEDs in the H11 socket. So I said let me write it here.
