Switching from 195 to 205
08.05.2020 14:54 # 1
dogu
Hello friends
i have 2006 model 307 90 hp
original 195/65 / 15`` tire on top
I wonder if I go to 205 floor, would there be a lot of fuel and traction?
or should I thin the cheek part
I'll handle the tire business this week
I am waiting for your advice and suggestions ...
08.05.2020 14:54 # 2
Ozgur
YES, LET US TAKE FRIENDS WITH TIRE RECOMMENDATIONS. I WILL BUY TIRE THIS WEEK.
08.05.2020 14:54 # 3
GokhaN
you may understand that 1 cm difference as a little play in the fuel, but the rest of the things do not change much.
08.05.2020 14:54 # 4
dogu
say friends
h
t
v
what's the talk?
speed performance or something?
08.05.2020 14:54 # 5
TA3537
continental contact 2 H series TA3537 2010-10-08 22:42:37
08.05.2020 14:54 # 6
TA3537
Speed limits that the tire can withstand H series 240 250 km / h speed tire
08.05.2020 14:54 # 7
voodoo
See you in the fuel ... of course, because of the surge of the tire to the ground more than naturally Göz Kırpma
08.05.2020 14:54 # 8
Doktor
I use 215mm, there is a 17 "rim on it. Of course it reduces the fuel and traction a bit.
08.05.2020 14:54 # 9
EK-6
If you want to install 205 tires, you can use the correct size 2056015 without any change in your rolling measure.
08.05.2020 14:54 # 10
dogu
date ......
08.05.2020 14:54 # 11
ali oncu
I don't think anything will change as you won't change the rim and only move from 195 to 205. I suggest michelin as a brand.
