Switching 207 triptronic from 1 to 2, is it a problem?
08.05.2020 16:55 # 1
berko
Hello friends, a friend of mine got 207 triptronic, the vehicle shouts when shifting from 1st gear to 2 and makes the gear much more noticeable than other gear changes. other gears are very smooth but when I change from 1 to 2, I couldn't comment because I didn't use a triptronic vehicle before, is there a problem or is it normal in & nbsp; 207?
08.05.2020 16:55 # 2
berk2309
While you are overwhelming with the gas, or if you are going to press and pull it out, if you are going to shift, or while you are in the middle of the course, it is like throwing on the jacket and then the gear is shifting.
08.05.2020 16:55 # 3
berko
My friend has just started to use an active vehicle, I gave him the possibility, but he does not press the gas very much, he does not go over half the gas and does not pull out, he pretends to be wasted as you say and then throws gears. berko 2012-07-18 23:31:39
08.05.2020 16:55 # 4
berk2309
Connect it to a computer and if it doesn't fail, they'll want to open up your big chance. & nbsp;
08.05.2020 16:55 # 5
berko
Thank you, a situation that should not normally be, then I need to handle the gear shifts before the warranty expires, so that it is something that depends on usage, then berko 2012-07-18 23:41 45
08.05.2020 16:55 # 6
berk2309
should not be a status tab & nbsp; If you have a guarantee, I will get it done without ending, otherwise it can cost a lot & nbsp;
