Switch key construction for Peugeot 206 (I got it done
08.05.2020 16:59 # 1
ginger
Instead of replacing the original key seen in the photographs, the old and the new ones are side by side. I did not do this work, but I am explaining how it is done with the details for friends who have a question mark in mind. The keymaker is disassembling your original key, a plaque with a circuit inside and a small piece of black color 4-5mm that looks like a useless piece near the part of the key that is in contact with the key. there is. The key parts of your original key and the switch of the switch, where you get the same key tip, are also compatible (for example, your cheap key is perforated, you get a hole with a hole) circuit, the black piece is beautifully placed in its new container. 50% of your key is ready. All that remains is to open the tip of the new key. You can do it with the machine in 5 seconds like the classic house keys. The process of pasting the lion logo on the key is OK. You can use it to open the door in the old empty key (it does not start the car since we disassembled the imbolay). In the meantime, thank you to SERCO from the forum for your suggestions, advice and ideas. I am summarizing, the new container is taken, the circuit and the imbolizer particle inside the old container are put into the new container, it makes the unlocking end of the new control, the lion logo is attached. My industrial adventure, * Of course, the job was not as simple as I did above. While I was here today, I went to Bostancı auto industry while I was there. 4-5 shops that I entered per second "said that it will not happen," he said that he would not work if I show his pictures by phone. He said there was burr, how much I said 85Tl but he sent 80Tl tradesman said. Hand is selling at 35Tl, the best pile on the internet let's give you 40, I said $ 5 on eBay. He said "Take it from eBay then my friend." I said you do not intend to sell anything, * They gave prices around 80 TL in other shops. I asked how much he said, the apparatus that makes usb to original tape is 165TL, 160TL. Postings on the site from the owner in the form of 130TL !!! They are rude ... Anyway, I asked another shopkeeper where the keymaker was, the place they described was in a neighborhood between the houses. It was not a shop surrounded by accessories. * Hello, I said we should make it snap. Let's do it, he started to disassemble. I said stop, how much. He said 35TL. I said continue to disassemble. We had a lot of trouble, he brought goods from abroad and followed the market tightly, and I laughed at what I experienced during the day. The room is having trouble, especially megan2 is sending an empty remote control out of the city, the guy lives in Anatolia, the keymaker wants the price of 120TL for the coding, what are we putting together, they do not come down, so what will be so exaggerated. I liked the man properly trades, prices like people, follow current products. It is recommended to forums. TAGS: Peugeot 206 switched key production, Peugeot 206 switched key construction, Peugeot 206 key production, 307 type switch key construction for Peugeot 206,
08.05.2020 16:59 # 2
EErgul
It makes me really happy to see such trades. what am i encountering during the day. people are satiated now.
work is great in good workmanship. The fastening does not stop on the buttons. But the key from the slot is not like the original button or something, it bothers me, so I never get into this. fortunately it looks better than the old key :) good luck. & nbsp;
by the way, if you still haven't thrown the old key you smashed, if I don't need to buy the back cover? the metal peugeot emblem on the back has fallen I want to change the back cover of mine with the solid
08.05.2020 16:59 # 3
ginger
Thank you for your valuable comments.
If you mean the switch to open the switch, the switch is not a very special button, it is already oval and silver colored. In other words, I am sure the form is the same as the original one because it is the same form. Like the original I put on the logo, the lion's ties are not separated, but engraved on a black plate, but according to the saying of the master.
I'd like to share the lion of my key with you, but if I have a problem later, I want to keep it for now, so that I can get the upper plastic buttons and return to it. The master I mentioned has your original key and its tip. Whether you replace ten back covers and mount them on the old end, you pull the end from zero. He said the price is 20 TL. If you wish, an opinion may have a lion out of his hand (he had some key scraps :))
08.05.2020 16:59 # 4
EErgul
yes I'm talking about the button of his voice. Maybe it was simpler than I got in my hands. don't worry about yourself :)
well be well then. it is very difficult for me to find that master because I am at Kocaeli :) I will stop by one day if I get on my way. & nbsp;
08.05.2020 16:59 # 5
ginger
If you are selling from the owner, our master will handle it as much as possible :)
08.05.2020 16:59 # 6
EErgul
I just bought the key container from the owner for 20 TL. if you need it, there is also a friend's switch wrench at cheap price but someone who will work like a friend key is hard to find here :) we continue with old keys
EErgul 2012-08-19 01:41:38
08.05.2020 16:59 # 7
ginger
Any keymaker that actually has a normal key making machine can do it. He picks the same tooth into otek. You can pass the contents of the cabin exactly to the one in your cabin.
08.05.2020 16:59 # 8
Serkan
Good luck my friend, the master told the truth about the lion logo, the 308 key has the same lion logo.
08.05.2020 16:59 # 9
serkan719
Aha the same as my key:) & nbsp;
I had it built when I first got the car.
08.05.2020 16:59 # 10
acemi pecocu
Can my key make the same match one by one, or the master makes my accessory & nbsp;
08.05.2020 16:59 # 11
Serkan
[QUOTE = beginner pecocu] Can my key make the same one, if the master does not make my accessory & nbsp; [/ QUOTE]
Only the container in this picture is changing, the new tip is opened, the spare key is made separately 70-90 TL remote control between 200-230 TL If you want to turn it into a snap, 30-40 TL
08.05.2020 16:59 # 12
zgr
I wish I had it made, but my original key ring is oval and there is only one button. Is there any key to it?
08.05.2020 16:59 # 13
blinddark
95 85 80 and 35, the man who does his job well is obvious.
08.05.2020 16:59 # 14
acemi pecocu
[QUOTE = Serco05] [QUOTE = beginner pecocu] Can my key make one same partner, master or do my accessory & nbsp; [/ QUOTE]
Only the container in this picture is changing, the new tip is opened, the spare key is made separately. Between 200-230 TL, if you want to turn it into a snap, 30-40 TL
[/ QUOTE] Thank you bro for your trouble and reply
08.05.2020 16:59 # 15
Oktkor
The container I bought for $ 3.6 came from Aliexpress. I opened it and put the chip on the newcomer. I went to the unlocking and opened the end. He asked for 10 liras. Oh, huh. I will go and settle in China now.
No, the Chinese of this hand are selling at our half price and still making a profit.
08.05.2020 16:59 # 16
OguzhanKucuk61
[QUOTE = Oktkor] The container I bought for $ 3.6 came from Aliexpress. I opened it and put the chip on the newcomer. I went to the unlocking and opened the end. He asked for 10 liras. Oh, huh. I will go and settle in China now.
No, the Chinese of this hand are selling at our half price and still making a profit. [/ QUOTE]
Assuming I have 50 pounds for the key cut and switchblade, yours is nice price
08.05.2020 16:59 # 17
Oktkor
[QUOTE = OguzhanKucuk61] [QUOTE = Oktkor] The container I bought for $ 3.6 came from Aliexpress. I opened it and put the chip on the newcomer. I went to the unlocking and opened the end. He asked for 10 liras. Oh, huh. I will go and settle in China now.
Assuming that I have 50 lira for the key cut and switchblade, yours is the good price.
08.05.2020 16:59 # 18
I switched cap and tip puller cost 25 TL
08.05.2020 16:59 # 19
Badur
Hello. Can you link? The product you bought from AliExpress
08.05.2020 16:59 # 20
dejawu1978
well, I don't have jeeps in the key & nbsp; "Big & nbsp; a key embedded in the hard plaque you know ..? How does it open or work the car if it is without chips ..?
Page : / 2
