Swipe left
08.05.2020 17:38 # 1
Texas16
Hello friends, my problem is that I changed the wheels and tires of the vehicle 2-3 days ago (I took 2 hands) and cut the springs (original) 4,5cm. ...
08.05.2020 17:38 # 2
KenBlockJR
You say I bought a second-wheel and tire. It would be a miracle if he did not.
If you have tried the rim-tire front and rear, it is likely to be from the springs. I advise you to give 50TL and buy a 5cm bow. your problem may be fixed
08.05.2020 17:38 # 3
vbmaster
The problem will certainly be solved.
08.05.2020 17:38 # 4
samet206
If you take a second hand from the springs, it pulls if there is a deterioration in its structure.Also the wheels do not hold balances, it is old or there is a blow. you should focus more on other reasons ...
08.05.2020 17:38 # 5
reality59
If the master who cut the springs made the wrong calculation and cut it and made the wrong pressing, it may be due to it, or it may not have been able to make the place where you last rot. tire pressure may vary, tire tread depth may be different.
08.05.2020 17:38 # 6
Bugra
I will suggest something very simple to you. Lift your vehicle with a jack. Swap front right and front left. attach the right to the left and the left to the right. then walk. if the vehicle starts to pull right at this time. It is made of 100% tires.
08.05.2020 17:38 # 7
emre_akdag
[QUOTE = KenBlockJR] You say I bought a second wheel and tire, you said I cut the springs. It would be a miracle if he did not.
[/ QUOTE] +1 Don't go out and get my friend, springs up to 50 TL.
08.05.2020 17:38 # 8
Texas16
We tried it, the only thing I haven't tried is to buy another bow.
08.05.2020 17:38 # 9
rolandgarros
[QUOTE = 307bursa] Who did you cut the bows from? (amazed brother?) [/ QUOTE]
broadcaster amazed brother LOL
08.05.2020 17:38 # 10
Texas16
ercümente hazer oto
08.05.2020 17:38 # 11
tigerland
If you have made a tie rod adjustment or you have broken the rods, the vehicle pulls ..
08.05.2020 17:38 # 12
Texas16
[QUOTE = tigerland] If you have made the rot adjustment, if you broke the rods, the vehicle pulls .. [/ QUOTE]
Rotcuda stems from bows, I said 2-3 rotcu, usually they said bow ..
