Swing bar. Problem
08.05.2020 16:08 # 1
Engin Tepe
There was no such problem until I installed these directional tires in my vehicle, then the problem came out:
steering wheel was inclined to the right and as it started to turn right into the vehicle.
Rot balance 2 times the camber settings were neither necessary. The tires that we call unnamed directional were mounted at the back again, it did not change again, the last allt was the adjustment, we fixed the steering column, and this time, the simit tilt to the left, but when the car is straight, we did not make any sense when you correct the sinmit i.
The front wheels were made to the right and left again after the tests.
As I said, this was not a problem until I installed the directional tires. I did not go into the pit, I did not hit the sidewalk.
Burak also saw what this says: D
& nbsp;
< / DIV>
I found this original, says
& nbsp;
Engin Tepe 2011-09-19 21:26:34
08.05.2020 16:08 # 2
sahin-peugeot
hello,
:)) is the brand of the origin manufacturer, not original that swing they want 96 TL for a 50 lira swing:))
08.05.2020 16:08 # 3
Engin Tepe
I saw it as it came to my job: D
08.05.2020 16:08 # 4
sahin-peugeot
"Laugh"
08.05.2020 16:08 # 5
Engin Tepe
Today I saw that the air of the tire was low, and I took it, and we looked at the right rim and there was a bend. It did, but it did not. still little mink is missing air, he said nothing more to do.
08.05.2020 16:08 # 6
tazmaniac
The problem you wrote was exaggerated after the swing change. ..when the swing has changed, your
