sweating in the engine
08.05.2020 15:52 # 1
karayel207
Friends, 207 vehicles approached 5000 km. I saw sweat-like wetness at the top of the vehicle's engine. Is this normal for you? Thank you ...
08.05.2020 15:52 # 2
I don `t get it
08.05.2020 15:52 # 3
karayel207
Let me write more explicitly. After taking a long way for the holiday, I looked at the engine of the vehicle. The oil filler cap looks like damp on the top of the engine.
08.05.2020 15:52 # 4
Hodja, first of all, your vehicle is good. What is called engine sweating is the small amount of oil stains on the outside of the car's engine block. In my opinion, there is no such thing for the vehicle within 5000 km. Besides, you said moisture. If the vehicle is stuck in your head under the warranty, I would like to stop by the service.
08.05.2020 15:52 # 5
denizcAn
The same problem happened in my car, I said oil is missing. I took it to the service. They Said That Such Events Are Normal In Hot Weather. Recently I took the service to the service vehicle. I cleaned the engine. No Problem Right Now.
08.05.2020 15:52 # 6
Emre Ekrem
It's a hot and normal situation. Sweating is a very different situation and Menderes explained it perfectly.
08.05.2020 15:52 # 7
karayel207
It is not a leak of oil anyway. As if it was wiped with a dirty cloth, there was no trace.
08.05.2020 15:52 # 8
metin
[QUOTE = karayel207] It's not exactly a leak of oil. It looks like it has been wiped off with a dirty cloth. Let's stop by the service ... Thanks for the answers ... [/ QUOTE]
Do you see a decrease in oil or water? If it has missed the oil, it will also mix with water. Did you look at the water in the tank where we put the radiator water of the vehicle?
if the engine is hot, it is not water but oil. Because not much water will stand on the hot engine, it will evaporate immediately.
08.05.2020 15:52 # 9
karayel207
I looked at the cold engine. Let me take a look at the engine water then. Thanks.
