Superb sound
08.05.2020 20:03 # 1
hus3yn
While the friends have been on the road for a few days, there is a constant noise coming from the front, even on the asphalt road, there are small jolts, this noise is very interesting. Where do you think the problem might be?
08.05.2020 20:03 # 2
conywolker
From which side can you look at the zrot of that side?
08.05.2020 20:03 # 3
dejawu1978
Enter a rot-balance what he has to tell you all ...
08.05.2020 20:03 # 4
monalos
Can make from shock absorbers. It makes it from the lower tables, so you have to have a look, when it shakes from the front, the car is shaking like a cradle, it can be a shock absorber. You will hear the sound of the brake, the bottom plate, but when it goes on the stable road, it makes a lapping in the pits and the shock absorber came to me.
08.05.2020 20:03 # 5
JunioR56
I had the same problem with my car, and I started doing it again soon. chronic to me. solution
There is an iron piece across the front two wheels. what is my arm of balance. it is screwed under the car with two tabs. these earbuds do not grasp the plastics when they are old and there is a crackling sound when the car flexes. This is how it will loosen these two arms and cut the inner tube together and squeeze back. Good luck with.
08.05.2020 20:03 # 6
hus3yn
I forgot the subject, we came from z rots, we changed, thank goodness
08.05.2020 20:03 # 7
I am glad that the problem is solved, unfortunately, our peugeot meets very often, thanks to our pit problems, thanks to our pits.
08.05.2020 20:03 # 8
JunioR56
They made cars like girls, but peutos are very spoiled. I spent 1000 TL for the bottom team, I got a year and then clicked back. Do not worry, my teacher will see the cold and cold water 1 It starts again in 1.5 years.
08.05.2020 20:03 # 9
ben_erhan
I was going to buy a front set from the peugeotmarket. When I read these messages, I said that I do not get the original good again.
Original tie rod end 75tl. Double 150. This is one of the cheapest parts on the front
08.05.2020 20:03 # 10
JunioR56
One of the support wedges in the z-rod is torn. I saw the master and gave a list, 700 TL was cool. front shock absorbers support wedges tie rod spindles bellows incl bend tires. the old master took me right, he took two right tie rods and put one upside down on the left wheel. The man said he was a master, and I remembered him with mercy from the past.
Evil SmileEvil SmileEvil SmileEvil SmileEvil SmileEvil SmileEvil Smile
08.05.2020 20:03 # 11
Exactly, there is a master, there is a master, you will not leave any other vehicle to others.
