sunroof wick
08.07.2021 21:01 # 1
oates55
hello, the sunroof wick is completely worn out, it is absolutely unusable, is it possible to install the wick or is there a solution, thanks in advance
08.08.2021 20:05 # 2
oates55
guys, as I wrote, I wonder if I can get help with the wickCry
20.08.2021 23:48 # 3
oates55
With the worn wick, the On/Off switch was defective. After my research, I couldn't get it to show that the zero was around 670-800, because it was around 400 liras, I followed aliexpress for 1-2 months, today including taxes. I bought it for lira. I wanted to announce to those who need it.
01.06.2023 13:01 # 4
oates55
I solved the wick problem. I wanted to give you some information. I bought black silicone. I applied a 1mm thick piece of hard plastic to the edge of the sunroof, turning it 1cm inside the sunroof to create a mold. I applied the silicone, it dried, I removed the hard plastic, and I've been using the sunroof for about two years without any problems. No water leaks. Since I couldn't find a wick, I found this solution. It looks like the original.
24.03.2026 13:05 # 5
ucgenauto
Hello, we at 3Gen Auto have helped our Peugeot customers with these kinds of problems. We are just a phone call away and can solve your problem immediately with guaranteed results. LANDLINE: 0212 276 9494 MOBILE: 0537 939 4292 ADDRESS: Atatürk Auto Industrial Site, 2nd Section, 30th Street, No: 1187, Maslak / Sarıyer, Istanbul https://static.cloudflareinsights.com/beacon.min.js/v8c78df7c7c0f484497ecbca7046644da1771523124516" integrity="sha512-8DS7rgIrAmghBFwoOTujcf6D9rXvH8xm8JQ1Ja01h9QX8EzXldiszufYa4IFfKdLUKTTrnSFXLDkUEOTrZQ8Qg==" data-cf-beacon="{"version":"2024.11.0","token":"11ac6a036a5c4b83a3c20a30a3bc3ba2","r":1,"server_timing":{"name":{"cfCache Status":true,"cfEdge":true,"cfExtPri":true,"cfL4":true,"cfOrigin":true,"cfSpeedBrain":true},"location_startswith":null}}" crossorigin="anonymous">
