SUNROOF STITCH ...
08.05.2020 21:28 # 1
407 ERHAN
Mrb friends, water from the sunroof of my 407 car and the smacking flows into the car, I even hear the wind noise on the road, the wick needs to be changed, I called the sunroof repairman in Ankara, he said he did not have a wick in hand, where can I find it, from whom or can you recommend it from the internet? I wonder, thanks ... 👍 407 ERHAN 2020-02-18 11:37:01
08.05.2020 21:28 # 2
erhan abicim expenses to be clogged. There is also such a subject. systems with your same tools
08.05.2020 21:28 # 3
407 ERHAN
Soner brother, hello again, how are you, we could not chat for a long time, thank you very much for your answer, but there is no problem in the expenses, Ankara showed it to a sunroof at the bewilder, he said what you said, the air in the drain channels but nothing changed, because the problem was in the sunroof tire , the wind sounds on the way, there was nothing like that before, the wind started to get water from the front left corner of the sunroof, from the place that corresponds to the head of the driver, not less or so, water flows like a little pet bottle, in heavy rains and while the car is being washed, water enters, I called several parts from Istanbul, in Istanbul, they said that they did not have a sunroof wick in their hands, and that I would find it difficult, too. I was depressed.
08.05.2020 21:28 # 4
407 ERHAN
If I cannot close the place where the water enters, the vehicle will decay with this trend, do I think the sunroof dimensions of other brands and models are the same, so is it standard, do I warn their wicks?
08.05.2020 21:28 # 5
Thank you, brother, we are good thank you. brother roving issue is troubled especially in sanroffs. I remember the same as 307. You call this wick on the sanroof glass you call this wick. You can use this type of wick instead of silicone.
I think the sanroof is not a wick, it is missing from the place where you give the linte where you walk. or the setting of the glass may be impaired.
08.05.2020 21:28 # 6
407 ERHAN
Thanks soner, now there is a tire on the edge of a sunroof glass, and there is a tire on the ceiling like a frame in the sunroof window, I don't know exactly which one needs to be changed, but one of these tires probably has a crack or some other opening, because it both gets a lot of wind noise, it is also taking water, but the sunroof setting had not occurred to me, I think it may be necessary to make a very fine, precise setting, because there is not a visible gap, soner, nobody understands about it, unfortunately, when I come to an annual summer vacation in ankara, this setting to the sunroof that I had previously visited you have to show your job, peugeot 307 can also fit the sunroof wick maybe as you say, stay alive buddy, good luck, kib 🭀
08.05.2020 21:28 # 7
407 ERHAN
Not only peugeot 407, but in general, there is a problem with this sunroof wick in the peugeot.
08.05.2020 21:28 # 8
just like my brother if you were in a troubled track, i would have helped I have two in my new vehicle, I would like to disassemble and repair them both. I did.
20.05.2021 19:41 # 9
407 ERHAN
Hello friends, I opened this topic last year, I still could not solve the problem of wind noise and water intake from the sunroof, because I did not have the opportunity to go to the sunroof repairman, but today I bought Würth tire care and refresher spray, seller friend, I said that this spray will soften the dried wicks and make them a little fuller. , he said that it will prevent sound, dust and water from entering, there are no cracks or tears in my sunroof glass wick and rubber anyway, I guess because it deforms over time, there is a very light micromillimeter opening in between and I guess this spray will work, I haven't used it yet. I will let you know the result here, I hope I will give you good news, and if you have any experience or ideas and suggestions on this subject, I would be very pleased if you write, thank you, see you guys...
