Sunroof maintenance, repair - Well known winter has come |
| 08.05.2020 18:05 | # 1 |
![]() Water in every vehicle (I speak for 307s) ![]() Plastic part to which the water is attached. You also see the iron bar that attracts and pushes the piece at its tip. We fit these plastic parts on both sides of the water formation. If the gutter is not attached, it is inevitable to enter the water at an advanced level, it takes as much as it takes and the only solution is the cancellation of the sunroof. If you can't see the water trough, it has either dropped somewhere in the ceiling, or if you bought a second hand, it may be in the owner. ![]() We fit the water trough. If the plastic part is broken (I have broken it) Let's stick it with strong adhesives. It keeps well. ![]() As you can see, after sitting, it is right in the middle and the incoming water flows to the water drainage pipes. We have these pipes on all four sides of our vehicles. If you open the sunroof even in low rain, the water will not go uncomfortable here. It is also very nice in spring rain. It is inedible. In a bay with your lover, you can think of the light in the rain. What you do is up to you. ![]() You can easily access the discharge pipe inlets on the front two sides. These may be blocked and the vehicle will get water even if you have groove. You can open them by holding compressed air with the help of a compressor. There is something to say, these hoses may be torn, you can change the hoses, the hoses pass behind the poles on the right and left of the windshield. You know, those floors are plastic and come to your hand when you grab them by the edges. ![]() Since my original button broke down, I found the solution to install this button. You know, normally there is a grill style place where that button is located, and water drips from there. In addition, the incoming water will spoil the color of the floor, fade, sag, and most importantly, it will enter the motor cables and lamp cables connected to the sunroof and make chassis. This event must be taken into consideration. It is not clear what the result will be. Sunroof maintenance is important for the comfort, safety and standing of the vehicle. Otherwise, you will have to glue completely and cut the water until you solve the situation like me and it is not nice. After doing these, test with pouring water while the sunroof is closed. You don't want to get caught in the rain. With regards to your cruise and information. |
| 08.05.2020 18:05 | # 2 |
Health to your hand Doğan, very good sharing.
| 08.05.2020 18:05 | # 3 |
Thank you Serkan.
| 08.05.2020 18:05 | # 4 |
Here, the friend has shown and explained how the hoses have changed. [TUBE] http://youtu.be/5oc7nuef9ec [/ TUBE]
| 08.05.2020 18:05 | # 5 |
tongucuk |
you did a good job born ![]() |
| 08.05.2020 18:05 | # 6 |
Thank you, Ramazan. My sunroof was tight. When some of my friends saw what I wrote about the subjects and sent a private message, my sunroof was pouring water, so I wanted to open up this issue.
| 08.05.2020 18:05 | # 7 |
The born friend told me really well, but if I try to do this, the complete sunroof will remain in my hand :) one of the sunroofs that caught my other attention, the extra opening and closing button there made you yourself too. there is the same problem with me. By the way, thank you very much for sharing this information. |
| 08.05.2020 18:05 | # 8 |
Thank you, Mr. Evren. We made that key with a friend who understands electrical and electronic work. It's not that hard but if I tell you as I did, I can do something wrong. They will do 15-20 pounds, do not give more.
| 08.05.2020 18:05 | # 9 |
Tebirkler has been a useful sharing. |
| 08.05.2020 18:05 | # 10 |
Thanks bro.
| 08.05.2020 18:05 | # 11 |
It would be like hooking the subject, but I chose to write here instead of opening the title. My tool turns back to level 1 when I do 307 xt.Sunroof is not working at the top and back slowly, do you have any idea for it? Note: now i saw the friend has the same problem with me http: // forum.peugeotturkey.com/forum_posts.asp?TID=24648 [QUOTE = SZKR] I'm also worried about this sunroof reset job. http://forum.peugeotturkey.com/forum_posts.asp?TID=24648 All functions work smoothly but; It does not open back to the last level. When I bring it to the last tier, it returns to the second tier. When I press it from outside, the windows close but the sunroof remains unresponsive. Reset doesn't work either, I am using it like this (: [/ QUOTE] LuTeRiS2015-03-06 12:49:33
| 08.05.2020 18:05 | # 12 |
WHERE THE SAME PROBLEM IS FOR SALE SUNROOF MATERIAL
