Sunroof button
08.05.2020 18:48 # 1
syz33
I have a 2003 Model 1.6 premium 307 vehicle, when you bring the sunroof button completely to the opening side, 1 stage opens and presses a little when you turn it on or off. There is probably a lack of contact. I did the reset as I read from the forum, but the result did not change.
I removed the button and cleaned the inside of the contact cleaning spray (as far as I can squeeze through the side gaps).
Now I think that if I open the inside of this button, I will solve the problem, but I am afraid of distributing it when I open it.
Thank you in advance.
08.05.2020 18:48 # 2
zr`lmn
I have that same problem. When I say I open it again, it closes and it turns on 1 step towards the inner part. I reset it a few times but it always does the same problem
08.05.2020 18:48 # 3
syz33
When you make the button right and left, it gets better and it opens completely. When it stops, it doesn't shut down again unless I close it but it is bad to remember. Is there any interested ...
08.05.2020 18:48 # 4
hsnsnl
you can not open that button, yaw, if it hurts, it is not enough to collect it again .. the best extractors are not a piece that is broken very much.
08.05.2020 18:48 # 5
okan77
Dusting and dirt trapping of the Sunroof slides prevents the closure in a way. Stops the engine to protect it. It happened to a friend of mine, he cleaned it from the top. There is a piece that rises up when the sunroof, which is called a fly screen, opens. Make sure it works well on him. If the slots are filled with dust and dirt, it affects the closure ... okan77 2014-09-19 10:07:08
08.05.2020 18:48 # 6
syz33
I guess the problem is in the key, I looked at the key, not like it will open, I did not open it because I was afraid that it would not be collected. But thanks to the forum, there are so many friends in the forum that they have no practical refurbishment. They offer practical solutions that work very well. beklemedeyim Evil Smile
08.05.2020 18:48 # 7
okan77
[QUOTE = syz33] I guess the problem is in the key, I looked at the key, not like it will be opened, I did not open it because I was afraid that it would not be collected. But thanks to the forum, there are so many friends in the forum that they have no practical refurbishment. They offer practical solutions that work very well. beklemedeyim Evil Smile [/ QUOTE]
Zero prices between 100-140 TL ... It is not something that deteriorates quickly ... Actually ... It is necessary to remove it from another 307 and try ... Whether the problem is with it ... It happened to me at once. When I first bought 307 ..: ) my friend said that the automatic sunroof closes when you go over 100 km ... We opened it when we went 100-110, we couldn't close it again. Officially it sank comfortably :) We reset it has improved .. I had no problem again ... My mind got stuck now what could happen ...
08.05.2020 18:48 # 8
syz33
Yes, if it actually coincides, it is necessary to remove it from another vehicle and try it, but it is not around me. When the sunroof is open upwards, it closes slightly after a certain speed, and when I stopped it, it caught my attention from the sunroof movement, I think 1 stage closes.
08.05.2020 18:48 # 9
baris033
I have the same problem right now. Did you find a solution? I will be happy if you give me information
08.05.2020 18:48 # 10
MadTurk_
When you reach a certain speed, a stage closes and when you slow down, the button returns to that position.
