Summer Maintenance of Your Vehicle ...
08.05.2020 15:21 # 1
The way to use your car that you drive in all kinds of adverse weather and road conditions without saying rain and mud in winter is through a good maintenance. According to the information received from the authorities of the auto services, especially the front wheels of the cars used in harsh winter conditions without regard for snow, rain, mud should be checked. Suspensions and shock absorbers can cause malfunctions due to roads deterioration as a result of snow-fighting work, and cars often get in and out of pits. Stating that general maintenance of the axle should be done, the authorities recommend not forgetting to renew the rot-balance setting. It is pointed out that brake maintenance will not be neglected except for the front teams; The pads need to be maintained, replaced if necessary, and the brake fluid level checked. In engine maintenance, it is required to clean the spark plugs and replace the air filter if it has reached 10 thousand kilometers. In addition, engine oil, pollen filter, gasoline filter, radiator water, antifreeze level measurement, the degree of activation of the electric fan, control of the belts are recommended. It is pointed out that the maintenance of the battery is not neglected, it is stated that the oxidized battery heads should be cleaned with hot water, and if the battery water is exhausted, it should be reinforced with pure water. Stating that tires are vital on long roads, service officials point out that winter tires should be removed. Control of the wiper blades, maintenance of the air conditioning and ventilation system, and headlight bulbs are also considered as other points of attention. Is your car ready for summer? Apart from the periodic maintenance performed at certain kilometers, the cars should be serviced according to the changing seasonal conditions. If you want to use your car, which has worn out under the adverse road conditions of the winter season, during the summer, these days when the spring begins to feel itself is the right time to make a care from head to toe. You should have your car checked from head to toe as if you had a check up. A seemingly simple malfunction can lead to serious problems later in the day. The way to drive your car without a headache during the summer is through a good maintenance. The front sets of your car, which you drive in all kinds of adverse weather and road conditions without saying rain and mud in winter, is one of the sections that should be checked. You should definitely have the brakes vital in your car. After the checks are made, you should also measure the braking distance of your car. You should definitely check the brake discs or pads for problems. Another part to check is your car's gas tank. If you have traveled frequently on snowy icy roads in winter, there may be leaks in your car's warehouse caused by scratches caused by bad road conditions. What should be done in summer care? The things to be done for summer maintenance are as follows: "Steering hydraulic oil should be checked. Antifreeze level should be checked. Battery heads should be checked and acid level should be measured. Batteries should be measured in dry charged batteries. Charges should be checked if the voltage is low. Check spark plugs. and if the glass water is missing, it should be completed.Wiper blades should be checked and replaced if necessary.It should be checked the antifreeze level of all four seasons.The electric fan should be checked. If it is old, it should be replaced and the clamps should be renewed. The brake fluid must be changed, as it absorbs moisture, the brake pads should be checked, if it is thinned, it should be replaced. Air gaps in the brake hydraulic pipes must be removed. Since the disc mirrors will quickly bend and deteriorate due to heat, they must be turned or replaced. The air gap in the hoses connected to the radiator should be removed. Articulated air flow systems in the dashboard should be cleaned and oiled. Luggage and upholstery should be dried and cleaned and their belts renewed. "
08.05.2020 15:21 # 2
Muhammet CAKIR
Thank you, Colonel, there is a good sharing tool.
08.05.2020 15:21 # 3
metin
Nice share.
I am sure everyone knows a lot of the information here, but there are small but important points that we forget among them.
08.05.2020 15:21 # 4
black_rock
thanks
08.05.2020 15:21 # 5
What do you mean, I don't know a place to be lubricated in that area
the albaydemirc 2011-04-28 13:13:03
08.05.2020 15:21 # 6
[QUOTE = Muhammet ÇAKIR] thank you, my colonel, nice sharing vehicle has a blessing :) [/ QUOTE]
What It Means Our Duty Is Service ...
I Will Be With You With New Photos Monday The Vehicle Is Evolving At The Garage ...
08.05.2020 15:21 # 7
[QUOTE = text]
Nice share.
I am sure everyone knows most of the information here, but there are small but important points that we forget among them, and care must be taken while maintaining.
You're right, brother, but most of us don't know.
Even I didn't know some
