Suggestions?
08.05.2020 13:59 # 1
Friends, I want to do something suspended to increase the vehicle's grip, I am unstable I do not want Istanbul roads to be too low, but at the same time I do not like the gap between the tire and the fender :)
I need something so that I will pass through the barriers comfortably, the grip will be solid and there will be less between rubber and mudguards :))
There are 16 rims, I need your valuable opinions.
08.05.2020 13:59 # 2
You will wear 3.5 to 5 glass springs, my brother, this is the best procedure to be done in line with your wish, and you will be supported by sports shock absorbers.
08.05.2020 13:59 # 3
What is Serhat Hodja's cost?
08.05.2020 13:59 # 4
springs in sports dampers between 200-250 ytl. Something between 500-800 varies between 800-1000 ytl of average cost, you can only wear it in the spring.
08.05.2020 13:59 # 5
okay, teacher, let me stop for you, I am the best
08.05.2020 13:59 # 6
Hope dad you finally found the right way :)
If the goal is to have a positive effect on road holding, I would never recommend dealing with a spring, I would recommend a sports shock absorber or coil over, and if you support it with the tower tensioner, there will be a noticeable increase in the road grip of the vehicle.
08.05.2020 13:59 # 7
Yes, Deran teacher, I will make a spring + sports shock absorber, I will buy the carbon tower tensioner in you then it is okay :))
08.05.2020 13:59 # 8
Eibach 5 cm Spring
Cone Shock Absorber
Tower Tensioner
You get a tremendous grip.
08.05.2020 13:59 # 9
Can I get a safe passage for embankments besides the road grip,
08.05.2020 13:59 # 10
Let my head be comfortable Diozan then 3,5 cm Eibach Plug.Eibach Springs are Sporty Street Springs.
But After Installing The Shock Absorber, How Many Cm Bows You Put, You Need To Pass The Sets Very Slowly.
08.05.2020 13:59 # 11
[QUOTE = gs5165] Can I get in the safe pass for the sets beside the road grip without touching the car [/ QUOTE]
You will swallow the gold and let it be pleasure. Smile
08.05.2020 13:59 # 12
Drean, my teacher, you know, when I drive under my car, I say "I will enjoy" :)
I think I'll wear 3.5 :)
08.05.2020 13:59 # 13
don't forget the tires ... it wouldn't be bad if you change the size of the slide tire.
08.05.2020 13:59 # 14
No tires are considered new, up to a maximum of 10000 km 5-month sizes 205-45-16
08.05.2020 13:59 # 15
HakanGokdemir
[QUOTE = DERAN_TUYNER] [QUOTE = gs5165] Can I get a safe pass for the sets beside the road grip without stealing the car [/ QUOTE]
My friend, I would say listen to Deran brother, I did not listen, do I support my outgoing money, or to the labor I spend, or to the time that goes? I did not have a 4 cm bow, I went and bought a 6 cm bow, the most ideal coil ...
08.05.2020 13:59 # 16
ixtanbul
For road holding, you should definitely not forget the tires + sports shock absorber + spring
08.05.2020 13:59 # 17
In fact, I would like to listen to my dear teacher, but he says he is hesitant because he says that you have to cross the smallest height, so I do not want to rub the bottom of the vehicle all the time.
08.05.2020 13:59 # 18
[QUOTE = gs5165] yahu, I really like to listen to my drunk teacher but he says he is my only hesitation because you have to cross the smallest height, so I don't want to rub the bottom of the car constantly [/ QUOTE]
Dad, there is a word. If you change it, it's okay. There are additional places under the rocker, they will surely protect the bottom of the vehicle even if it is a little bit. Smile
08.05.2020 13:59 # 19
:))) illa 5 cm ha :)) yahu deran my teacher, if i reduced my wheels, if i bought my original gti rim, it would drop the room a little tool?
08.05.2020 13:59 # 20
You come to me in the car, how do you sow six in a car ...
