Suggestion for Printing Balata
08.05.2020 17:50 # 1
error
Hello friends, while saving money for the exhaust cost, I came across the pressure pad. Authorized service wants around 1000, what would you suggest? vehicle gasoline 2.0
08.05.2020 17:50 # 2
Alicilik
What is the demand for yaw 1000tl or flywheel?
08.05.2020 17:50 # 3
error
Well, they took around 500 liras for workmanship and they said something about 400 liras for the set price. Thumbs Down
08.05.2020 17:50 # 4
hsnsnl
if I think 600 mercury outside
08.05.2020 17:50 # 5
error
I will say that if they say 1000 on the net, I will say on the eyw, but I do not know either of them.
08.05.2020 17:50 # 6
Alicilik
Teacher, learn exactly what will happen, one like a surprise egg. The master goes to the thousands of cars you say, brother, this is going to change, this may change, but he says you will get you 10000km ass. Our master, we are giving the car to the man, he walks around the street, then the brother says, "After the work, come on, eyw, we have not had any problems until now.
08.05.2020 17:50 # 7
error
I have not come across a competent authorized service team, as you said for years, I have visited all of them except for the active people in Istanbul, and I visited all of them except for a few of them. I have a voice that I think, if I put it together like a "valve fit" cut into the clutch pressure, they will mix their heads thoroughly, they will not be able to give a net price.
08.05.2020 17:50 # 8
Alicilik
[QUOTE = errör] Well, as you said for years, I did not come across a competent authorized service team, I visited all of the authorities in Istanbul, except for the active euphoria and a few more. For a few years, there is a sound that I think it came from the prisk ball, and if I put it together, it will be confused, they will not be able to give a net price, as usual. > "Smile"
I cannot say that your job is difficult. I would be helpful in Ankara, but it will be interesting for friends in Istanbul.
08.05.2020 17:50 # 9
kuscu38
Learn the price of your brother, 500 pounds of labor will not be available if you want to go to industry. The price of the set is between 306 and 280 to 350.
08.05.2020 17:50 # 10
KenBlockJR
I changed the timing set + press pad to 700
08.05.2020 17:50 # 11
Alicilik
I hope it finds the price if the flywheel is involved, there is no problem in the flywheel.
08.05.2020 17:50 # 12
error
let's look at the thanks, thanks for the contributions I will investigate a few places, bosch etc ...
08.05.2020 17:50 # 13
oguzhan29
search for a master or something, look for a master, find out that it is usually expensive in the service.
08.05.2020 17:50 # 14
error
friends, I got an average price of 500 from the maslak bosch service for the print set, I will go at the first opportunity, but everything is on top of each other, yes it came, Istanbul today I said let me turn on the air conditioner, it will cool better when it is 5 tl in ready gasoline, but let me see what it smells like a gasoline. What is officially air-conditioning blowing gas ? Is the gas hose cracked or is it a chronic thing in 307?
08.05.2020 17:50 # 15
elsoberano
gasoline smell is not a chronic problem & nbsp; (I do not have such a smell for now) I got the price for 500-600 except for the press brake pad 1000 If the flywheel is not included, a high number & nbsp;
08.05.2020 17:50 # 16
error
Well, it increases fuel consumption as if this is a problem, but there is a danger dimension.
08.05.2020 17:50 # 17
elsoberano
Have you looked at the bottom of the injectors or is there a leak in the fuel system, hoses etc. coming from the pump?
08.05.2020 17:50 # 18
error
Well, neither smell nor something under the hood, it is clean but I am sure that the smell of gasoline comes from the ventilation ducts of the air conditioner ..
08.05.2020 17:50 # 19
sezar206
[QUOTE = Buyer] My teacher, learn exactly what will happen one like a surprise egg. The master goes to the thousands of cars you say, brother, this is going to change, this may change, but he says you will get you 10000km ass. Our master, we are giving the car to the man, he walks around the street, then the brother says, "After the work, come on, eyw, we have not had any problems until now.
Whom are you bringing the vehicle to me? The other day I put the car into service, I said, let me check out a pure and well-intentioned master, let's do what I need. I say it will be okay, brother, or it needs to change immediately. I have been using it for 3 years :)
08.05.2020 17:50 # 20
error
I opened a different title for the smell subject ...
