Suddenly the headlights went out !!!
08.05.2020 17:25 # 1
ttaylanaa
When I gave a signal for a certain period of time, I felt that the signal was not working, or rather stiff. When I was playing a little with the arm, it was getting better. I didn't care much about it.
When I was in the city tonight, my headlamps suddenly went out after about 2 seconds. I was really scared, I was on a dark intercity road, I was going with 90. I did not have a place to stop at that moment, and after 3-5 minutes I encountered the same situation again. I pulled to the right, stopped (it took 2-3 seconds to go out). I opened the hood, touched the cables going to the headlights or something, no problem ... I traveled another 60 km, and the same thing never happened.
To summarize:
- I did not encounter any trouble except the signal problem. .
- Even though I never touched the arm on a straight road, the headlights turned off (I wasn't giving any signal)
- It was 5-10 km with the headlights activated ...
- There were 2 problems in the first 20 km of a 80 km road and the remaining 60 km did not repeat. (My speed is 50-60 km / h)
Do we have friends who encounter such a situation? What is the problem with my vehicle? Thanks to everyone interested in advance.
(2005 307 XR petrol + lpg) & nbsp; & nbsp; & nbsp; & nbsp; ttaylanaa 2013-03-10 23: 03:33
08.05.2020 17:25 # 2
ndm01
About 2 years ago, a similar incident happened to me, I had a similar problem with the vehicle of my brother-in-law on the Antalya coastal road. I stopped at the first place, I checked and checked, there was no problem, I went back to the road, the same problem happened again, I managed it for a long time and it was okay, it was okay, I used the car a lot and then the same problem appeared, I went to the authorized service again. They said the fuse box needs to be replaced if you want to have a check on the fuse box.
08.05.2020 17:25 # 3
307mer
Hello, I had the same malfunction. complete signal arm assembly changed. unfortunately they do not do repairs. If you find dating, 150-250 TL or zero to 800-1000 pounds are requested.
08.05.2020 17:25 # 4
ttaylanaa
Thank you for your interest.
Is there a problem with both the arm and the insurance? Of course I can not know without looking, but I want to know a little about the subject.
Headlamps fading signal lever on the fuse signal ?? ttaylanaa 2013-03-10 23:23:31
08.05.2020 17:25 # 5
volkanC2
I don't know if the guy I bought a sports steering wheel in 106 was from him, but when the steering wheel was flat, I was having a hard time to move the signal lever up or down when I slightly turned the steering wheel, but then this mechanism either broke or broke, the signal lever is very relaxed, but when I turn the steering wheel in the opposite direction, There is a problem "Unhappy" & nbsp; it happened to me a few times when it came to the event of extinction, but it flashed when I touched the signal lever in seconds my headlights have been several times but never happened, I burned my headlights the other day, but none of my indicator lights lit up, I touched the arm immediately burned, I did not encounter such a problem, my idea is at the signal arm there in trouble, my idea. & nbsp;
08.05.2020 17:25 # 6
tolike
Friends had happened to a friend such an incident I worked almost a day on the vehicle and I saw that the fuse tray had liquid contact with glass vapor and the sockets were oxidized, the problem was solved by cleaning the table with cellulosic thinner and brush and installing the last sockets with oil. respects
08.05.2020 17:25 # 7
suppor
Since I do not want to open a new subject, I am writing here, I realized that my fog was burning when I was going on the way to bigukorhan last day.
08.05.2020 17:25 # 8
herry
There may be a shortage of insurance, it is possible to ski from the installation.
08.05.2020 17:25 # 9
TaZ
I would like to enlighten you on a subject I know. There is a headlight role on this fuse box. It is definitely not possible to repair if your headlight is damaged if it is on it. If it is possible, it is possible to separate it from the press because it is pressed with the printing machine with its plastic parts around the brain, so if you try to separate it, be sure to the brain. When you go to the electrician, they say that the brain will change, it will not be repaired directly, they say & nbsp; 560 TL in the brain as far as I know. There is a much cheaper solution for this. 15 tl worth of hawk roles in all the cables on the cables and the headlight role problem disappears, it can not easily make any master, it encourages you to take the brain directly, whereas the material does not keep 40-50 tl with workmanship. Now for the purpose of saying this, we came to our friend's pejo for a while after the headlight went on for a while, the headlights turned off, the headlights turned off, the headlights did not go off, everything was working normally, but the headlights did not go out, we tried it in his car and we did it, and the result is painlessly closed.
08.05.2020 17:25 # 10
ahmed206
[QUOTE = suppor] Since I do not want to open a new subject, I am writing here that I realized that my fog was turning on the way to bigukorhan last day. / QUOTE]
My brother, your problem was when I first got the car, I had it too, sometimes the signal was not on, I was turning on the fog, it was turning off after 2 minutes, it was turning short and sometimes short. Master solved it free with contact spray. & nbsp; It's been about 8 months, not repeated. Probably there is oxidation somewhere at the bottom of the wheel.
08.05.2020 17:25 # 11
akantek
[QUOTE = ahmed206] [QUOTE = suppor] Since I do not want to open a new subject, I am writing here that I realized that my fog was getting cold on the way to bigukorhan last day. I couldn't give you what is the solution [/ QUOTE]
My brother, your problem was when I first got the car, I had it too, sometimes the signal was not burning, I turn on the fog, it turns off after 2 minutes, it turns long, sometimes it turns short. Master solved it free with contact spray. & nbsp; It's been about 8 months, not repeated. There is probably oxidation somewhere at the bottom of the steering wheel.
kon " How is the plug spray something like, lining spray? Couldn't we spray direct lining spray? "Smile"
