Suddenly the airbag light came on
08.05.2020 14:15 # 1
ibrahim YILDIZAK
On my way back home from work with my Peugeot 206 2003 model car, the airbag light came on suddenly and is still on. What should I do? Unhappy
08.05.2020 14:15 # 2
Sinan
there is a problem with me :) it did not go out still burn. May be due to com2000
08.05.2020 14:15 # 3
fourus_06
There is a material on the steering wheel, such as a film, when there is a disconnection in it and it is usually disconnected.
08.05.2020 14:15 # 4
ibrahim YILDIZAK
I asked the master, he said the same thing, but I did some research, and I read that someone was talking about an incident like water escaping into the BSI brain, the engine was washed today. It may be a situation. Where is this socket mentioned in the socket?
08.05.2020 14:15 # 5
fourus_06
I am not sure that it may be under the seat, I do not want to mislead it. Connect it to a device and delete the error.
08.05.2020 14:15 # 6
ibrahim YILDIZAK
What nonsense this is, what a troubled car I am going to eat, somewhere ends, somewhere begins pff :(
08.05.2020 14:15 # 7
fourus_06
Do not worry about such things, bro, don't worry.
08.05.2020 14:15 # 8
Long Beach
Greetings, I had the same problem, I had contact with the plug under the seat, I pulled out the plug and I got it.
08.05.2020 14:15 # 9
hasimayaz
If the seat belt warning lamp is present, check the plugs under the seat. otherwise it is necessary to look at the computer and check the malfunction. High probability of com2000 short circuit
08.05.2020 14:15 # 10
haruncoskun
Fix the 206's problem is not a problem, I think it turns on and off
08.05.2020 14:15 # 11
okankrgz
First of all, there may be a lack of contact with the sockets or cables under the seat.
08.05.2020 14:15 # 12
ErkanKurnaz
I have the same, I erased it again. But be careful with the com2000, I want to press it to turn on the left signal, for example, it activates the rear wipers when it operates the front wipers. mine is probably due to com2000.
08.05.2020 14:15 # 13
ibrahim YILDIZAK
I took the car to an electrician recommended by my master today, there was something in the steering wheel (I think you mentioned the com2000), it was due to him, he took care of it, he said, I went and gave warning again before 10 minutes, and I will explain the results again. dynamic82 2010-05-14 00:34:54
08.05.2020 14:15 # 14
mahmutq
I have the same problem in my car, I am wondering what the result will be
08.05.2020 14:15 # 15
cevdet
the washer probably played with the sockets while cleaning the bottom of the seat. I don't think it's a serious problem. I hope the problem is solved if you check your sockets ..
08.05.2020 14:15 # 16
hasimayaz
com Don't play too much with 2000 reels .. it would be well pert. If you find it, don't go out.
08.05.2020 14:15 # 17
ibrahim YILDIZAK
The problem is that on the Com2000 rollers, I found that these rollers could break and crack as time went on. 150TL Original cost 450 TL. Thumbs Down
08.05.2020 14:15 # 18
fourus_06
I hope the vehicle will not upset you bro
08.05.2020 14:15 # 19
ibrahim YILDIZAK
Amen, I mean, sometimes I come up with an apple.
08.05.2020 14:15 # 20
behzat
Get well soon Embarrassed
Page : / 2
