Suddenly rising heat
08.05.2020 15:23 # 1
boraa
3 months ago, my vehicle, which was replaced at the service of the temperature sensor, last night was not stiff, long distance, etc., the temperature indicator needle struck, the STOP lamp flashed. Ouch
08.05.2020 15:23 # 2
When you looked at the hood openly, the coolant was really hot. Hos, I don't know how you could get it, but at least there was something like smoke and steam?
08.05.2020 15:23 # 3
aclern
http://forum.peugeotturkey.com/forum_posts.asp?tıd=14525&title=%ddlk-altrmada-hararet-gstergesi-yany is
Take a look at this issue, perhaps the same problem. My problem was solved by itself yesterday. It may be the same problem with you.
aclern 2011-05-05 13:31:27
08.05.2020 15:23 # 4
boraa
Master, my temper must have changed for 3 months. So I don't think it's from him. I'll take it to the service this day, but what will be related to that surprise? Confused
08.05.2020 15:23 # 5
boraa
Sister named Koliva. Everything was normal. so keep on behalf of temperature Confused
08.05.2020 15:23 # 6
[QUOTE = boraa] sister with koliva nickname. Everything was normal. so keep on behalf of temperature Confused [/ QUOTE]
Look at the thermostat, brother
08.05.2020 15:23 # 7
boraa
ose307, I will do it now. I'm going to the service now. Let's see I will write the result here Göz Kırpma
08.05.2020 15:23 # 8
If the thermostat did not open, I think the car would be overheated and boil water. When the water boils, the vapors are released. Because the cover of the expansion tank starts to open at 1.4 bar, it protects the installation. the motor would be pretty bitter at that time.
As far as I understand, the car is not really overheated ...
the cecol 2011-05-05 15:11:55
08.05.2020 15:23 # 9
mehmetugur
The same thing happened to me, my teacher, the automatic gear shifted to 307 p and the temperature was over, and when the stop text came out, or when it was put into gear, it took it back to the service. water or something could have escaped.
08.05.2020 15:23 # 10
axi206
[QUOTE = boraa] Master, my temperature sensor has changed for 3 months. So I don't think he is from him. Confused [/ QUOTE]
There is nothing deteriorating in 3 months. original product may fade out from factory
08.05.2020 15:23 # 11
boraa
I left the vehicle to the service last night. Ouch
08.05.2020 15:23 # 12
metin
the usual bragging, when they get stuck, this is chronic, don't you worry and they send you (:
08.05.2020 15:23 # 13
boraa
No, master, I am hard on those issues. Even if the vehicle arrives , it is not necessary to send it without earning money.
08.05.2020 15:23 # 14
mon
But seriously, this problem always happens in pejoes. I also have 206, the temperature indicator in the heavy traffic goes up to 95 100 degrees.
08.05.2020 15:23 # 15
[QUOTE = mon] but seriously I always have this problem with pejos. I also have 206 in the heavy traffic temperature indicator 95 to 100 degrees. [/ QUOTE]
This temperature is quite normal. It is so in all cars. The trouble experienced here is suddenly a jump in heat. The two events are very different.
08.05.2020 15:23 # 16
boraa
Telephone from the service; `` The vehicle has been tried again with all new parts, but the same overheating is again. `` What do you think happens to this end? Confused
08.05.2020 15:23 # 17
[QUOTE = boraa] Phone from the service; `` The vehicle has been tried again with all new parts, but the same overheating is again. `` What do you think happens to this end? Confused [/ QUOTE]
Let me say, they didn't understand the car.
First of all, let me ask about the presentation. Does the temperature level in the display return to its original state after a while after the sudden rise in temperature? Or does it drop to zero again reach 90 or does it stay there once it reaches the red level?
I can offer water solutions, making sure that all parts are intact.
1. If this event also happens when you operate different tools in your vehicle, for example, when the headlights are on, the lengths are on, the rear window resistor is activated, etc. etc. .. Then there is a chassis problem in your vehicle. They need to know the solution very simple but to correct it.
2. Look around the gearbox when you lift the hood. You'll see a thick black cable there. One end of this cable is fastened with bolts and the other end goes somewhere. This kind of problem also occurs when this cable is broken. Have a check done.
08.05.2020 15:23 # 18
boraa
Master; the indicator will be restored after a while ..
1. It does not depend on any hitches. It rises at any time. It comes to an end. The fan works. After a while it returns to normal.
2. I will say the cable but if it cannot solve such a simple problem in the service, it is a pity ...
Let's see the car come. I may sell the car. Maybe they will tell me that the Peugeot services will not know that they will not do any solid work, but now they will be right. Confused
08.05.2020 15:23 # 19
metin
Did I say cem brother is from a thermostat? Embarrassed
08.05.2020 15:23 # 20
[QUOTE = boraa] Master, the indicator will be restored after a while ..
You servant services, try to be your own car master. The masters in the place you call the service are working as if they are training in the factory. No. They find the way to trial and error and some experience. They are stuck with a little unusual problem.
I think the problem is the chassis problem. Check what I wrote in my previous message and share the results with us. Let it be easy now.
Page : / 2
