Sudden revs up in 4th gear
08.05.2020 19:44 # 1
viges
Hello, I am new here, I have a problem with peugeot 206 hdi desire model, I noticed about 3 days ago when I put my car in 4th gear, when I gave gas to the end of the car, when I pressed the gas until the end, it sounds like 2200 3000 revolutions, the car sounds like empty gear, but it does not accelerate, it continues to accelerate after 3000 revolutions. so it can cause a gap between 2000 and 3000 times thank you
08.05.2020 19:44 # 2
ALLEX
[QUOTE = viges] Hello, I am new here, I have a problem with peugeot 206 hdi desire model, I noticed about 3 days ago when I put my car in 4th gear, when I put the throttle in the 4th gear, that is, when I press the throttle until the end, it sounds like 2200 3000 revolutions, the car sounds like empty gear but it does not accelerate. It continues to accelerate after 3000 cycles, so there may be a gap between 2000 and 3000 cycles. Thank you [/ QUOTE]
Brother probably misses the clutch.
But he must be doing all the gears. I just don't think he'll be in 4th gear.
Automatic or manual vehicle.
08.05.2020 19:44 # 3
viges
manual gear, I looked at all the gears, you notice, only doing 4 gears
08.05.2020 19:44 # 4
samet206
It feels like it to you, but it does it in all gears. It seems to me that the print is missing the pad, or it may be a problem with the gearbox, but the pressure seems closer to the pad.
08.05.2020 19:44 # 5
viges
I understand, thank you. How much does it cost?
08.05.2020 19:44 # 6
KidCabrio307
[QUOTE = viges] I understand, thank you. How much does it cost? Do you know how to change this print pad [/ QUOTE]
I recently asked for a price. Original 670 pounds. They said it would be 490 pounds if you do not buy a voucher. Instead, you pay around 300 to 400 labor.
08.05.2020 19:44 # 7
viges
08.05.2020 19:44 # 8
mistercasper
There may not be an incontinence in the lower gears yet, but try it in 5th gear, if it is not necessarily the same event in it, there may be another problem, but the big good clutch
08.05.2020 19:44 # 9
mbsb44
In addition to the press pad, the transmission is caused by oil leakage, which is a problem during 3 to 4 traction or in sudden throttle load when in 4 gears.
