Sudden increase in speed
08.05.2020 19:53 # 1
mrtttt53
Friends, I'm tired of telling a problem, but unfortunately the car doesn't get tired.
Now, my new problem that I noticed is (206 1.4hdi); 1, 2, 3, 4, 5, that is, when I press normal gas in all forward gears, when it passes 2200 cycles, it suddenly comes to 3000 cycles with 2 spinning sensations. I thought it was time to change, I even pray, so that there is no turbo or injector for pressure. What do you think looks like?
08.05.2020 19:53 # 2
Gokcesel
You think right, teacher, it is time to change the pad.
08.05.2020 19:53 # 3
samet206
Exactly what you are talking about, the vehicle is skipping, the changeover to the press pad is likely to be served again, of course.
08.05.2020 19:53 # 4
mrtttt53
Thank you guys.
I did not know when I did it, but he only did this problem 1 or 2 times 10 days ago.
08.05.2020 19:53 # 5
OguzhanKucuk61
I suffer from the same trouble. What amount does our clutch kit include workmanship?
08.05.2020 19:53 # 6
mrtttt53
If i don't know wrong; I heard that the clutch set is 200-250TL, 70-100TL if the gearbox oil will change, sometimes it may be necessary to turn the handwheel when changing the clutch set, and of course labor, 500 600 ... ☺
08.05.2020 19:53 # 7
OguzhanKucuk61
Maşallah maşallah Aslan wore this order
