Sudden gas cutting of 306 gti
08.05.2020 15:13 # 1
kaptan21
Hi friends, my name is from Mehmet Diyarbakır, I have a 1998 model 306 gti car. My problem is that when the car is driving, it suddenly cuts off the gas, the motor slows down as it stops, it gets better when I pull it out of the gas and it does it, sometimes it makes me bored. I am waiting for your opinions if there are masters who have knowledge on the subject or friends who have the same problem
08.05.2020 15:13 # 2
berk2309
Well, I have a bole in my mind. I have a problem with 307. I did not show it to me when my foot was on the gas pedal.
08.05.2020 15:13 # 3
look at the gasoline pump, if my brother is faulty, it is because the gas is not coming. I had the same problem in me.
08.05.2020 15:13 # 4
kaptan21
vehicle lpg is doing the same fault
08.05.2020 15:13 # 5
Emre Ekrem
http://forum.peugeotturkey.com/forum_posts.asp?tıd=14132
This looks like the title you opened;
It may be a throttle (I do not know if it is electronic). If this problem occurs when your vehicle is traveling at different angles, it may be due to uphill, downward, gasoline level in your tank. The fact that it does not connect to the device and display a problem means there is no electronic fault, which should be a clue that you should focus on a mechanical fault.
Briefly;
gas butterfly
gas pump
plus your car also has lpg, which brand do you use? Peugeot does not have all brands of LPG systems, for example, a friend of mine had a Ramses sequential system on 306 1.8 vehicle and similar problems occurred to the problem you experienced, he removed all the problems by removing the system from the vehicle and replacing it with an experienced master.
08.05.2020 15:13 # 6
the throttle is not electric but old wired. There is also a throttle position sensor under the tab.
08.05.2020 15:13 # 7
kaptan21
I removed the throttle and cleaned it, but I did not get any results. I think it would not be done in LPG if it was a gas pump.
08.05.2020 15:13 # 8
dejavuer
Hello, my brother, I had the same problem. After 2000 cycles, it starts to cut, but it does not go away. It was okay, I advise you not to play with any part of the car ... you said you have it connected to the device? is déjà vu 2011-04-18 15:36:59
08.05.2020 15:13 # 9
kaptan21
No, it was not connected to the device of the authorized service or they couldn't connect it, so I say that in the private service, the engine was connected with the chassis number and it did not fail, but the problem is just like you wrote, brother, let's change the oxygen sensor as soon as possible.
08.05.2020 15:13 # 10
orhanetap
I had the same problem in wv polo polo 6n
suddenly he was cutting off the gas when he was leaving, and he would recover when I pumped the gas to the end.
it improved after butterfly and distrubitioner replacement.
08.05.2020 15:13 # 11
dejavuer
[QUOTE = captain21] no did not connect to the device of the authorized service or failed to connect it so I say that in the private service, the engine was connected with the chassis number and did not fail, but the problem is just like you wrote, brother, then let's change the oxygen sensor as soon as possible let's see the problem will be fixed [/ QUOTE] brother chassis and If you look at it with a detection device that finds the failures of the peugeot and not the engine number, the problem will arise
08.05.2020 15:13 # 12
dejavuer
If you were in Ankara, I would help you with 306 gti, but distances are
08.05.2020 15:13 # 13
kaptan21
[QUOTE = dejavuer] [QUOTE = captain21] no did not connect to the device of the authorized service or failed to connect it so I say that the engine was connected with the chassis number in the private service and did not fail, but the problem is just like you wrote, brother, then let's change the oxygen sensor as soon as possible. QUOTE] If you look at a detection device that finds the failures of peugeot, not with the brother chassis and engine number, the problem arises. [/ QUOTE] the device does not fail because it does not constantly fail, I am still looking for the oxygen sensor.
08.05.2020 15:13 # 14
cash1912
I have that same problem. I did lpg maintenance, I changed all the filters, I did the butterfly cleaning, I changed the spark plugs, I changed the gas filter.
08.05.2020 15:13 # 15
kaptan21
I hope that we will find the problem in the vehicle industry for a week now for a detailed research.
08.05.2020 15:13 # 16
kaptan21
friends, we haven't found the problem yet, will I do it from the map sensor?
Peugeot Forums - Peugeot Fan Club © 2025
FromOwner.co.uk — Buy & Sell Directly from Owners in the UK. No dealers. No commissions. Just from owners.
