Sudden Dial Drop
08.05.2020 18:39 # 1
denizcAn
Guys, I got in my car to go to work in the past days, everything is fine, I'm going with a normal 90, should the speed suddenly drop to "0"? I was shocked. Today it made the same fault again and the airbag light came on. I pulled to the right and STOP the car, it was ok when I started it, but I am sure it will repeat. Anyway let me cut short;
I would be very glad if you enlighten me about why this problem is caused, thanks in advance ...
Vehicle: 2011 Model Peugeot 206 Plus +
denizcan 2014-06-30 00:05:45
08.05.2020 18:39 # 2
Atix
I think the same problem was in my friend's 206 vehicle, which is a general problem but I do not know the solution.
08.05.2020 18:39 # 3
okaNStarss
Could there be a lack of contact with the speed meter cables? the displays on the panel have also gone
08.05.2020 18:39 # 4
206cc57
The same happened to me once a year in the traffic of the Bosphorus Bridge, it recovered without hitting it .. All the hands went down.
08.05.2020 18:39 # 5
toprak83
the same thing happens with me, then it heals itself ... 2006 206 ...
08.05.2020 18:39 # 6
denizcAn
yes guys this happened again this morning, and i also discovered something else the speed kicks the "0" when it gives light gas to the vehicle and kicks.
08.05.2020 18:39 # 7
alpdoner
The same problem happened to my 2004 model 307 xt vehicle. The speed dial and tachometer showed 0. Airbag lamp or something burned. The problem is the charger or alternator. When the vehicle's electrical equipment cannot supply enough voltage, the brain is absurd. I'll get it done before time may cause bigger problems in the future. I had the alternator repaired for 100 TL and 30 TL to disassemble it.
08.05.2020 18:39 # 8
ndm01
I have been living the same problem in my 206 vehicle for a long time, now I got used to it, sometimes it did not cause any trouble for months.
08.05.2020 18:39 # 9
DeRyCK
It happened to me 2 months ago. On the way to the road, all the hands went down to 0, and the wipers started working spontaneously without saying what's going on, the 4's started to light up, the headlight turned on and off spontaneously. I pulled the gasoline off the ignition and could not start again. The charge dynamo was broken, there was an electrician in my place where I stayed, I had it repaired for 3 hours.
I would like to have the charger and electrical parts checked, do not get bigger problems on your head. Get well soon.
