Subwoofer
08.05.2020 19:47 # 1
ozgorh
Friends I think 20 cm subwoofer, I don't have much budget, what would you suggest?
08.05.2020 19:47 # 2
ozgorh
Or there is no place in the car.
08.05.2020 19:47 # 3
mimit
If you can find an original powerbass 2xl is a nice product, but the brand's own unfamiliar counterfeits are available on the market, other than that, slim subwoofers can also be used as 25 30 cm. we do to listen to music. A separate option for 20 cm armpit slim bass.
08.05.2020 19:47 # 4
ozgorh
I researched a little, the wipers are fine, they fit me, but can you give me information about this? Do you use it? Do you do business? I have 2 double oval 1 double mid team but I want to put a bass but I don't have a place. can share who uses
08.05.2020 19:47 # 5
mimit
depending on which slim you use, it depends on whether it works or not. I was using vibe optisound at 308, when I go on the road or when you need luggage, it doesn't break the middle, but you can get a satisfying sound with a nice setting, what kind of information you want, if you get an active bass, it will already be on the amp. If you are going to need an amplifier to feed the bass separately, you have to pay 300 TL except for the amp, otherwise you will listen to noise, not music. As I mentioned above, the powerbass 2xl series beautiful device for 20 cm, if you can feed it correctly, you will not regret it, there is also a model that I intend to buy, powerbass df110t but the price is between 400 and 500 TL.
08.05.2020 19:47 # 6
Dadas-25
I am very pleased with the internet, I bought 220 tlye sony xplod 1800 watts. I already have a tube in the trunk, it was half empty. DaDaS-25 2016-05-15 23:45:44
08.05.2020 19:47 # 7
herry
Anfi that will feed the sub is also important
08.05.2020 19:47 # 8
ozgorh
Anfi alcam already has a second hand or zero mono anfi alcam stero anfim already have cadence swl 12 cv slim bass do you suggest how do you suggest anybody who use it is thinking to connect with a mono amp
08.05.2020 19:47 # 9
herry
I don't know how efficient the slim bass will be in the trunk, but there are armpits. düsünebilirisn
08.05.2020 19:47 # 10
mimit
After installing the amp, I don't think any tradesman will say no to this by trying slim bass of suitable powers, because the differences in intonation will be more obvious than the normal boxed bass, in the same way, the port with and without the port will also affect the sound. boxes) hits during rhythm passes, this is a good thing because I think you don't hear it if there is not really long bass in the song. Now, when I needed luggage in the vehicle, I was removing the box of 30 and continuing with the vibe slim, the room is called 20cm, but the speaker diameter is 20cm with 16 cm slot edges. two products were worth 300 rms. It is not much understood by the buzz, but you will learn about the optisound size with the video.
[TUBE] 3tbilrcvccq [/ TUBE]
