STROKER-USA-505 amp
08.05.2020 18:19 # 1
KIZILASLAN
friends pionerr 2550 bt tape 6965 v2 two speakers ts w309 woofer im my friend who is going to make the facility suggested the amplifier STROKER-USA-505 200 tl do you think this amp would be enough for this system (I want to listen to a high volume sound, I just want quality sound) How did I research a little bit? The same amp was released under the brand name jameson jameson -USA-505
08.05.2020 18:19 # 2
barishrocker
If it is the same as Jameson, do not get infected. Cadence xa125.4 is better, but it is not very logical to feed 4 channels sub. Sub is not a single coil? In addition, if the ovals are single even enough. If it is 2 pairs, 4 channels are not enough for all of them.
08.05.2020 18:19 # 3
KIZILASLAN
I do not know if the sub single coil speaker is the same as 1 set jameson. They look like the type.
08.05.2020 18:19 # 4
barishrocker
Cadence is an amp I recommend to several people. I don't know the user who has never seen Stroker.
08.05.2020 18:19 # 5
KIZILASLAN
I try to connect the amphitheater on Friday, I will write the amphitheater in good or bad.
08.05.2020 18:19 # 6
KIZILASLAN
We connected the stroker brand amplifier yesterday, but the performance did not bother me, engine sound, etc. It is the man who wears the amplifier to get it back, so I researched 3 amps instead.
one of these http://urun.gittigidiyor.com/otomobil-motor-aksesuar/pioneer-gm-5200t-2-kanal-760-watt-makgari-guc-101968331?id=101968331
one of these http://urun.gittigidiyor.com/otomobil-motor-aksesuar/pioneer-gm-6500f-4kanal-760w-oto-anfi-faturali-106527010?id=106527010
which one is better http://urun.gittigidiyor.com/otomobil-motor-aksesuar/sony-xmn1004-1000w-3-4-kanal-amfi-106432280?id=106432280
What is the difference between bidet mono and streo amplifiers
08.05.2020 18:19 # 7
oguzhan29
mono bass amplifier is a stereo column treble component amp, dual amps are used in professional installations, but those who say normal sound is enough, take 4 channel amps and give them to 2 channel bass and 2 channel columns.
08.05.2020 18:19 # 8
barishrocker
mono amps are only used to feed subwoofers. The first one they choose does not serve 2 channel amps. It is useful to buy 4ch or 5ch amp. I will make different suggestions from what they write, because for the subwoofer it is necessary to get a strong amplifier. or the pioneer 4 channel here and the mono amp for the subwoofer can be purchased separately.
cadence fxa 4100 or 5100
cadence xa 125.4
jbl 100.4
Also, if the engine is picking up, there may be a problem with the vehicle connection. For example, the power cable and RCA cables do not go through the same place. then the amp's chassis should be well done etc. etc
08.05.2020 18:19 # 9
KIZILASLAN
My 16 cm 6965 v2s are super performance even without amplification. I wonder if I buy mono amps and just connect the bass.
08.05.2020 18:19 # 10
barishrocker
Could be. In the future, you can reinforce with 4 channel amps and compenents when you fix the budget .. Mono amp plays better always subwoofers ..
08.05.2020 18:19 # 11
KIZILASLAN
so how does this Pioneer 6500 f amplifier have 4 channels 760 watts my tape 2550 bt 4 * 50 rms outputs. bass 309 free air ovals 6965 v2 6500 f amplifier how can this system
08.05.2020 18:19 # 12
KIZILASLAN
[QUOTE = dehsetilyo]
so the system would be complete Pioneer, maybe more compatible then
08.05.2020 18:19 # 13
barishrocker
I think the amp is inadequate for the sub. It is important whether it is compatible or not ..
08.05.2020 18:19 # 14
barishrocker
With that amp, you can feed 2 sets of ovals and take mono for the sub.
08.05.2020 18:19 # 15
KIZILASLAN
today I disassembled the stroker amplifier and connected the Pioneer 6500 f amplifier, pulling the motor sound from the previous amplifier did not have this amplifier bass, the stroker gives more bass than the amplifier stroker amplifier was sold by the plumber himself, it seems like I did not adjust this amplifier because it did not make any adjustments and did not like the amplifier. I think this amp was better than the previous amp had dealt with a lot of settings because anyway, how can I arrange this amp according to my head?
08.05.2020 18:19 # 16
KIZILASLAN
I searched a bit on the internet and made the settings of the amplifier myself. It was the number ten. It has a great bass performance.
08.05.2020 18:20 # 17
barishrocker
Good bye, good experience to you :)
08.05.2020 18:20 # 18
KIZILASLAN
just as good experience :)
