Strange sound from behind the vehicle
08.05.2020 17:52 # 1
Ayaz58
Good forums have been added to my cousin pejo family as of last week :)
The vehicle 206 hdi x line 2003 model has no problem, there is no problem, so the car is yawning on the ramp road, the hand brake is pulled, the car is yawning from the brake, one is right, I am very happy if you help with this.
08.05.2020 17:52 # 2
error
the pad can be sounded, normally you will hear a similar sound when you press the brake on ramps down.
08.05.2020 17:52 # 3
caster21
I can tell you to the drum, it may not sound like that, maybe it could be the shock absorber
08.05.2020 17:52 # 4
vbmaster
I have the same I was never stuck in it, I hear it for years. It didn't give me any trouble for 5 years. I wish you an accident-free day ...
08.05.2020 17:52 # 5
Ayaz58
Thank you for your cvp friends, but the back of the car has changed to the drum and the amorisors 9 original new but it is not going to sound, only when the car spreads and yawns, it is a sound that makes people die :) Suppose that you parked the car on the ramp, your car is looking down on it, it looks like the hand brake is pulled from the brake. but one vehicle is yawning or I do not know how we will hear this gacurt die sound, friends this is a matter of state :)
08.05.2020 17:52 # 6
pt206
[QUOTE = Ayaz58] Friends thank you for your CVs, but the back of the vehicle has changed to the drum and the amartisors 9 the original has changed but the sound is not going, only the vehicle spreads one way and stretches the car, a sound that makes the person creak :) When you pull it out, when you pull it out of the brake, I don't know how to get the sound of this emperor die.
same happens to me Smile I don't know if it's normal or not, but it's been the same since I received it, and I never wondered, actually the source of the sound. Smile
08.05.2020 17:52 # 7
Turgay_66
My teacher holds the front wheels of the vehicle in the normal brake press, holds the back when he pulls the brake, and when you release the normal brake, he starts to hold the rear wheels and at that time, the sound comes from the shock absorber because the rear shock absorbers collapse down, I think it is not a problem to come up. Turgay_66 2013-08-17 00:42:25
08.05.2020 17:52 # 8
vbmaster
aha that sound has been there for 5 years, I wasn't even stuck once :) I don't think it will be a problem, I wish you an accident-free day ...
08.05.2020 17:52 # 9
Ayaz58
Well, I said don't hang out to your cousin, but when I heard that seei, I was even disturbed and there was no problem.
08.05.2020 17:52 # 10
Ayaz58
Before the amartisors changed, the same thing has happened now, I don't think it was original and again, so be it, friends, that every pajcu has come to the contemplative consistency.
08.05.2020 17:52 # 11
This is an event that should be met normally within the framework of physics rules.
08.05.2020 17:52 # 12
qqyyxx
it does from the rear brake center and pads, but it is not an event that will require the brake centers and pads to be replaced.
08.05.2020 17:52 # 13
sercinho
It comes from the rear torsion. It is useful to look at the torsions.
08.05.2020 17:52 # 14
Ayaz58
Torsions were looked after, friends, problem, ball, miles, solid, thank you, I do not solve your problems, I think this is the chronic malfunctions of the piano.
08.05.2020 17:52 # 15
reality59
that sound comes from the rear drums. Enjoyable driving.
Reason;
The foot brake is connected to the front wheels and when the foot brake is pressed, the rear of the vehicle is lifted and the front is pressed, the rear drums are compressed when the hand brake is applied, and when you release the foot brake, the jamming of the instant drum slips and it makes a sound like squeaking the door due to friction, if you clean the drums yourself or a master you will get rid of this sound. It is not a situation to be obsessive, it reflects this sound more in places where there is only a ramp, this sound will be heard from your vehicle on the flat road, but since the vehicle has a low slip, the sound will not be so much and you will not notice it.
reality59 2013-08-18 11:03:38
08.05.2020 17:52 # 16
Bunyamin.Kar
[QUOTE = reality59] that sound is coming from the back drums. Enjoyable driving.
Reason;
Don't explain everything, don't be so legendary: LOL
08.05.2020 17:52 # 17
Ayaz58
Tsekkur bro, let's clean the drums like you say bidet and share the result
08.05.2020 17:52 # 18
okan77
Do not tamper if it works ... A word from China :)
08.05.2020 17:52 # 19
Ayaz58
Reason;
Hello friends, our problem has been solved. The back campaigns have been overhauled, the noise has stopped. Reality 59
