Strange sound from 307
08.05.2020 19:34 # 1
cnrars
Hello guys,
I have a 307 1.6 vehicle, the engine passes while stopping and starting, at least 10-15 inches goes back and forth while stopping, of course, and the labyrinth sound sound. I guess that's what's called a flywheel. Would it be a problem if I didn't change anything quite costly?
While the other issue is giving gas in the vehicle, it sounds like a harmonica sound like a second engine says, and the sound stops when you release the gas?
Why are these?
Thanks.
08.05.2020 19:34 # 2
The sound that comes in when stopping and starting is caused by engine chocks. I don't think it stems from the flywheel. That whistling noise that comes from the engine while giving gas is most likely because the v-belt is loose. show it to a master as soon as possible.
08.05.2020 19:34 # 3
cnrars
[QUOTE = sonerkyl] The sound coming while stopping and running is caused by engine chocks. I don't think it stems from the flywheel. That whistling noise that comes from the engine while giving gas is most likely because the v-belt is loose. show it to a master as soon as possible. [/ QUOTE]
hello, the sound coming from the lak lukur and the sound that sounds like an incredible lak lukur, which is like saying that I will continue to work as soon as the engine stops, and the sound that shouts as the lauk lukur is voiced, the other one will change as a set + oil is missing from the top cover, How about 1500 pounds cost averaged, do you think these figures?
