Strange sound from 307
08.05.2020 18:59 # 1
cnrars
My car does not matter when the engine is cold or hot, or when the air conditioner is turned on or off, while idling, I guess from the right side of the torpedo, there is a flickering, a little chills, when I press the gas slightly. going, it sounds as if the engine is cold, but it doesn't go away, I'm nervous, where might it be coming from?
08.05.2020 18:59 # 2
GokhaN
it can be anything. Even a plastic inside the torpedo can vibrate. When you say truck, it never comes to mind Smile
08.05.2020 18:59 # 3
KuzuX
It can come from the idler sensor. Can you open the hood and look? If you don't know what the idle sensor is, you can check it on google images.
08.05.2020 18:59 # 4
cnrars
[QUOTE = GökhaN] can be anything. Even a plastic inside the torpedo can vibrate. When you say truck, it never comes to mind Smile [/ QUOTE]
the torpedo is empty :)
08.05.2020 18:59 # 5
cnrars
[QUOTE = KuzuX] Can come from idling sensor. Can you open the hood and look? If you don't know what the idle sensor is, you can check it on google images. [/ QUOTE]
I don't think my teacher is related to this, because when there is vibration, there is sound, I think it would be a problem with idling, as you said, am I wrong?
08.05.2020 18:59 # 6
KuzuX
[QUOTE = cnrars] [QUOTE = KuzuX] Can come from idling sensor. Can you open the hood and look? If you don't know what the idle sensor is, you can check it on google images. [/ QUOTE]
False. Right now, there is a similar problem in my vehicle. idling engine has trouble crowding when the vehicle gets hot but I have no complaints about the cycle. For example, at high speed, 110 120 too crows. I asked the price in the piece, 50 TL supplier industry 100 TL original price. I will change this month. I asked the electrician if we clean it, it would be okay, I asked him. I also told you to give an opinion, maybe I will not know there is no problem in idling engine
08.05.2020 18:59 # 7
koray.turan
The same voice is present in me, but when I take my foot out of the gas, I hear them sound like a bolt.
08.05.2020 18:59 # 8
hakan574
my brother had me in the same audio strap, I just changed the belt, and after changing the belt, it doesn't have to fit properly or it does it again but mine was a bit more like a belt sound anyway
08.05.2020 18:59 # 9
206x-line
If there is a crater casing, we can look at it or a bolt loosening at the bottom, look at the glass water tank, check the headlight, the screw may be loose or look at the side mirror, it may vibrate, there may be clips inside the door.
206x-line 2015-01-14 01:20:20
08.05.2020 18:59 # 10
erdincs
The same problem I had in 307 after maintenance, I found this problem after investigating the reason for a little bit. I found the air filter hose touching the engine, so I did not want to sound it while the engine was working.
08.05.2020 18:59 # 11
That voice you're talking about is not a problem. That sound comes from a piece in the ten right hood. I remember it was about fuel, but I stayed away from the market and leaned LOL
