Strange sound and idling disturbance from my vehicle |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Partner tepee | |
| 08.05.2020 21:29 | # 1 |
My vehicle is the Peugeot Partner peak 2017 Allure hardware. There is a problem like this; I fill the tank completely, come and go, when the tank is over tomorrow, when the engine is running at idle, the noise of the noise is coming down and I wait for 10 seconds, then I start again, the hand on the tachometer falls down, it seems like it is drowning, I stop without stopping. It turns back to normal in 3 starters. It does not work at idle. This happened to me twice. I paid attention to it. I fill the tank completely. When I do it, I will say the diesel is dirty, but I always take it from the same place and I fill it completely. The guarantee of my vehicle is just as if it was done on purpose knowing very bored ...
| 08.05.2020 21:29 | # 2 |
sonerkyl |
First of all, welcome to us. If the previous maintenance was done at the authorized service, call the peugeot center and ask for a discount. When was the last time you replaced the fuel filter. we need to check the air flow meter. Of course, my advice is to have a special peugeot service with the original software in hand and have to look at the error codes there. you can look more suitable.
| 08.05.2020 21:29 | # 3 |
Thank you for writing the answer, the diesel filter has changed in 30000 km maintenance, the vehicle is completely authorized, so I did not want to take it to the private service. closes
| 08.05.2020 21:29 | # 4 |
When you work at idle, you can say that the noise is loud, the worst possibility is the inter-piston gasket burn.
