Strange problem that cannot be solved at 206
08.05.2020 16:16 # 1
clara
& nbsp; 2004 model 206 in between & nbsp; in & nbsp; It is & nbsp; and & nbsp; After & nbsp; battery & nbsp; now fixed by removing the pole head, & nbsp; I had the problem to write. & nbsp; A & nbsp; click sound & nbsp; then the airbag lights came on, the horn & nbsp; to play & nbsp; started and & nbsp; high beams & nbsp; He was burning. when I stopped the car, the engine & nbsp; stop & nbsp; though headlights & nbsp; It was closed. & Nbsp; the battery terminal & nbsp; When I take & nbsp; The problem that resolved was 10 days later & nbsp; again & nbsp; Learn by & nbsp; tool & nbsp; service & nbsp; I Gort, & nbsp; fuse box & nbsp; changed, after 20 km & nbsp; again & nbsp; I takrarla. something in the vehicle's brain & nbsp; or not the & nbsp; I was told. and & nbsp; fault & nbsp; still & nbsp; not found. what & nbsp; should i do ???
08.05.2020 16:16 # 2
berk2309
First of all, can we ask you to introduce yourself in the "Let's get to know our members" forum rules like this :)
08.05.2020 16:16 # 3
clara
ok :) let's meet
08.05.2020 16:16 # 4
If you bring the service to your service and leave the vehicle again, the problem caused by the problem box has not been changed, but it has not improved, I think you should return it to the service. the service is very vigilant about these kinds of matters.
08.05.2020 16:16 # 5
metin
" click sound & nbsp; then the airbag lights turned on, the horn & nbsp; started not playing & nbsp; and & nbsp; high beams & nbsp; not lit "
/ DIV> & nbsp;
I think it might be a com2000 situation where all of these are all together.
08.05.2020 16:16 # 6
Go to that fuse box, give it back, and they will not be able to charge you anymore.
08.05.2020 16:16 # 7
toprak
Get well soon friend. the same problem happened to me but only the airbag light was on. the battery had recovered when I removed and attached the terminal. we don't click for about 2 months: S guess your problem is / 80 brain related. & nbsp;
08.05.2020 16:16 # 8
[QUOTE = text] " click sound & nbsp; then the airbag lights came on, the horn & nbsp; not playing & nbsp; started & nbsp; high beams & nbsp; not lit " & nbsp ;
I think it may be related to com2000 where all of these are together. [/ QUOTE]
Yes it is likely to be from com2000. & nbsp;
08.05.2020 16:16 # 9
like me com2000
