strange buzzing sound
08.05.2020 16:26 # 1
akinbaglan
Greetings to everyone;
friends, I have probably experienced many of my problems, and I would like to ask the friend who experienced this problem and had it repaired, please, because there are friends who give a lot of money to the masters because of this problem. the problem is:
407 1.6HDI I have a car, especially when driving with 1st and 2nd gear, I probably have a strange buzzing sound coming from the engine or wheels, this sound is intermittent cuts out but comes out more in low gears. While I was driving on the highway today, I noticed that the same sound came when I was in 5th gear and at a speed of 100 km. If there is a friend who knows this humming sound that I cannot compare to something, please write it here. I know it is ridiculous, but I believe it is ridiculous and indescribable in this sound.
08.05.2020 16:26 # 2
06OzGuR06
A sound resembling a whistling sound that you call humming is coming from the turbo. Especially when the speed is rising in the cold engine, it is heard more clearly (in the form of vuuvvv). It is normal that the sound comes from the turbo. a thicker sound and & nbsp; if the sound becomes louder when traveling at high speed & nbsp; Can the vehicle be in gear or idle?
06ÖZGüR06 2011-12-10 00:27:59 < / edited>
08.05.2020 16:26 # 3
akinbaglan
There is no turbo sound, it does not idle, as I said, it is widely heard in 1st and 2nd gear. it looks like a humming sound made by a rapidly rotating shaft and is very disturbing. Thanks for be interested.
08.05.2020 16:26 # 4
Ucyuzalti
My car is not diesel, but when I bought such an audio car, they had no problem with the industry, I went to the service, said on the ball of flow, then I said I'll come back "LOL" I went to the master, the problem was over. Note: I did not find a voice in the industry, could not find the sound "Wink"
08.05.2020 16:26 # 5
Ucyuzalti
Does the sound cut off the motor load? that is, if it cuts off when the gas is rooted, take a look at the flow ball & nbsp;
08.05.2020 16:26 # 6
akinbaglan
No, not in the Yuke ride, when the speed is over 3 in 1st or second gear, it sounds like a milk machine (I could best describe it).
08.05.2020 16:26 # 7
06OzGuR06
[QUOTE = Three hundred six] My car is not diesel, but when I bought such a sound vehicle, it was not found in the industry, they did not find the problem in the industry. = "LOL" /> I went to the master, the problem was over. Note: I did not find a voice in the industry could not find the sound "Wink" [/ QUOTE]
Tool lifte they are going to take the wheels and look around if I am a master "Big
08.05.2020 16:26 # 8
06OzGuR06
Then this sound comes from the differential, it is high probability. Because the torque is high at low gears, it makes the differential sound. It still makes this sound when driving at high speed. .
Is there a decrease in the vehicle's traction performance?
08.05.2020 16:26 # 9
hhuzun
brothers & nbsp; If it comes from the wheel, the rauman ball may have been distributed. sounds like a whistling sound. if he is doing it while he is going fast
08.05.2020 16:26 # 10
hhuzun
There is no [QUOTE = akinbaglan], not yuke, it sounds like a milk machine when I was in 1st or second gear speed 3. As I said, the sound of the belly ball is broken
08.05.2020 16:26 # 11
06OzGuR06
[QUOTE = peace of mind] brother & nbsp; If it comes from the wheel, the rauman ball may have been distributed. sounds like a whistling sound. If he is doing it while he is going fast, it is because the ball is worn.
08.05.2020 16:26 # 12
hhuzun
[QUOTE = 06EWAG06] [QUOTE = huzun] brother & nbsp; If it comes from the wheel, the rauman ball may have been distributed. sounds like a whistling sound. If he is doing it while he is going fast, it is because the ball is worn. bosa was making the same sound on the gears. & nbsp; it would be nice to have a look again.
08.05.2020 16:26 # 13
akinbaglan
[QUOTE = 06ÖZGÜR06] Then this sound comes from the differential, it is highly probable.It makes differential sound because the torque is high at low gears. . Sometimes it is also very severe.
Is there a decrease in the performance of the vehicle's traction? sometimes it is cut and sometimes violent, and it is not when it is idle. I didn't feel a low performance but the car's fuel is a bit too much, the 1.6 HDI hash 7.2 bursts.
What do you think I should do to solve this problem? Will my differential change? How much will it cost if it changes?
Thank you for your answers now
08.05.2020 16:26 # 14
06OzGuR06
[QUOTE = akinbaglan] [QUOTE = 06ÖZGÜR06] Then this sound is coming from the differential. It is making a differential sound because the torque is low at low gears. It also makes this sound when driving at high speed. Sometimes this sound is interrupted. Sometimes it gets too heavy.
Is there a decrease in performance of the vehicle's traction?
< / div> yes, sometimes it gets cut and sometimes violent and it doesn't do it when it is idle. I didn't feel a low performance but the car's fuel is a bit too much, the 1.6 HDI hash 7.2 bursts.
Thank you for your answers now. Change the oil and try it as well.
There may be many reasons for the increase in fuel consumption.
Depending on your driving style, using at high speed increases the fuel.
Air filter If it is clogged again, it will cause an increase in fuel.
If your vehicle has winter tires, there may be some increase. Also, cold weather increases fuel consumption.
Are oil and filter maintenance performed regularly? < br>
06ÖzGüR06 2011-12-10 16:43:49
08.05.2020 16:26 # 15
akinbaglan
yes I do all of them regularly, these values are with the proper driving style, because when it was used a little aggressively, it was 8.9 even in the city. Thank you very much for taking the answer and answering it.
08.05.2020 16:26 # 16
06OzGuR06
Thank you. Fuel is really high, even my 2.0 HDI burns no more than 7 liters in city use. edited> 06ÖzGüR06 2011-12-10 16:59:14
