stops while on gas station.
08.05.2020 14:53 # 1
leventes
Hello friends, first of all congratulations to the Ramadan feast of all peugeot users and the Islamic world ...
Although my car showed my 1998 model 306 XR problem to a few repairmen, we couldn't find it. Since my car started to run on LPG, gas started to work after about 5-6 km. I showed it to LPG, they said no problem with gas. But until I go to 5 km distance, my vehicle stops at least 8-10 times, especially when I take my foot off the gas or turn the steering wheel when cornering, my speed is whatever my speed ... the first 5 km. There will be drowning in the vehicle as if there is no gasoline ... Thank you from now ...
08.05.2020 14:53 # 2
I used 94 model citroen zx at one point and had a similar problem. Don't let the guy tell me right away, "the older brother is too slow." I looked at the man's face, I said, what are you saying? You know ... when I explained the situation in the car, I understood it.
I guess that there is a problem in the warehouse. there is a problem like leaving with only a little gas ...
Well, let's fill the tank completely, will he do it at that time ??? If you overcome the problem in this way, you will add that you burn it every month and you will keep your tank full.
08.05.2020 14:53 # 3
leventes
Thank you, they connected the car to the machine for your answer. They had an external warehouse, and they guessed that it was the same problem from the brain.
08.05.2020 14:53 # 4
leventes
Meanwhile, the rev counter of the car rises between 10 and 30 while in the park :) let's see what they will say in the service
at least I will report the result of the friends who have the same problem know about it
08.05.2020 14:53 # 5
okankrgz
first look at the rolenti sender
08.05.2020 14:53 # 6
If you are spinning cycle ripple, you should first check the throttle valve throttle ... also does this ripple lpg grandfather?
the cecol 2010-09-11 14:01:21
08.05.2020 14:53 # 7
leventes
My vehicle works very well in LPG, I have no problem like shaking or stopping, just doing it on gasoline.
08.05.2020 14:53 # 8
bayelektronik
ah ah this lpg made my car like this my brain teacher brain .. whatever you do it does not improve. money goes in vain.
08.05.2020 14:53 # 9
hasimayaz
Butterfly cleaning + valves and sensors should be checked.
08.05.2020 14:53 # 10
leventes
yesterday I went to the service, cleaned the throat butterfly, replaced the spark plugs, looked at the idle valve, they said no problem .. they said that the lpg in peugeot is always problematic, they said that the problem of stopping could be from the cylinder head, brain or float ...
:) 306 xr for sale :)
08.05.2020 14:53 # 11
okankrgz
Even the dirtyness of the gas is ruining the idle. It happened to me ... I burned 50 TL gasoline until I started the dirt.
