Stops after 3000 cycles
08.05.2020 20:46 # 1
sLeymN
I have 307 diesel vehicles in 2003. While the vehicle is running, it stops after 3000 cycles. Sometimes it kicks at 2000 cycles and stops if I don't press the clutch. If I press it, it continues to work. Also, while I was standing, I looked at the exhaust section where the asphalt was black. Why could it be? Can you also recommend a proper repairman in Ankara?
08.05.2020 20:46 # 2
TIBBIYELI
First of all, my friend has passed .. I had a similar problem, there is a master, there is a master, brother ..
But I put it into the auto test, the oxygen sensor, the lambda sensor was defective, the bidet temperature change changed, I think the problem is solved ... I think I will look at it there .. About 250 new sensors .. get back again.
08.05.2020 20:46 # 3
sLeymN
Thank you very much. I had the same problem when it came to work. I left the car to the industry. Hope it is solved. Now, I passed through his money and got cold because of the troubles. He harassed officially. There are all chronic problems in the vehicle.
08.05.2020 20:46 # 4
sLeymN
just called the master, said the crank sensor needs to replace defective. Let's see if he changes, will he suffer from another place?
08.05.2020 20:46 # 5
Orcun.Dmr
I wonder if there is anything to do with the crank sensor on the asphalt enough to leave a mark on the asphalt. The air flow meter can also be tried or it should be checked from a computer with original Peugeot software. orçun.dm is 2018-02-15 01:04:02
08.05.2020 20:46 # 6
sLeymN
Hello,
I received the car yesterday (: thank you, repairmen, they made a 60 km test by car: D
Seems like no problem for now. Previously, when climbing on slopes, when the vehicle had difficulty or when I dropped the car and rolled the car, black smoke was coming out of the exhaust.
I tried again when I came home. 5 I was able to gas up to 6 thousand cycles, no black smoke came out of the exhaust. Now the vehicle seems to be smooth, I will act according to a few days of use.
