Stops 406
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 406
08.05.2020 19:49 # 1
Poyraz406
Friends first hello to everyone
I wouldn't stretch my car 406 hours, my auto2001 model vehicle stops on the way, how do you say, if I do not load much under 1000 cycles, for example, when I get up at light or jump from a car, the car stops, if I do not load it, I said that I changed it, I said I changed it, I said I changed it, I said, I changed it, I said, I changed it, I said, I changed it, I said, I changed it, I said it, I changed it, I said, I changed it, I said, I changed it, I said, I changed it, I said, I changed it, I said, I changed it, I said, I changed the filter If you can still help, I would be very glad to thank you now
08.05.2020 19:49 # 2
KidCabrio307
The same is present in my car. While waiting in the light, the vehicle stops while driving slowly in congested traffic. I think this problem is chronic in Peugeot.
Dude, does it sometimes happen when the vehicle kicks on the move and the "Antipollution Fault" warning appears on the screen ???
08.05.2020 19:49 # 3
Poyraz406
Until today, I haven't found a text like this. I guess we can't find the answer we want here.
08.05.2020 19:49 # 4
KidCabrio307
Since this is a very hairy breakdown, there is no one that can help. because there are other unanswered topics in the forum. but they have expert advice on that. if you want to show it to one of those masters
the http://forum.peugeotturkey.com/forum_posts.asp?tıd=41980&title=peugeot-106-usta-tavsiye
08.05.2020 19:49 # 5
Poyraz406
I searched a little online, I think it might be from the eccentric sensor my problem
08.05.2020 19:49 # 6
First of all, is there any LPG in the vehicle before the reasons for stopping?
08.05.2020 19:49 # 7
Poyraz406
Yes there is
08.05.2020 19:49 # 8
I think a problem with LPG is to make the priority LPG system passive and use it for 2-3 days. If it continues to be observed, I recommend you to check the coil - gas pump - spark plug - throttle and eccentric position sensor you call. If there is no problem in gasoline, if it is only doing lpg, have lpg map sensor - lpg heat sensor - regulator - lpg energy sensors also checked.
08.05.2020 19:49 # 9
Ugurcan57
It will be like hosing the subject, but we also have the same problem, there is a lpg in the car.
There are some people who say that the light on the display lights up when the car is on the road sometimes, the vehicle is getting air or something, this light is on, it ends after a short time
08.05.2020 19:49 # 10
Ugurcan57
The problem has been solved today, the complete spark plugs of the vehicle have been renewed.
08.05.2020 19:49 # 11
Thank you for your solution to your problem.
08.05.2020 19:49 # 12
ahmetyasar
Hello friends, my car is Peugeot 406/2000 model / D9 engine / gasoline, it has been 1 year since I bought my car and I had a zavoli brand tube 9 months ago.
In my problem, it counts as the friends on the page. I bought my car at the beginning of May and there was no problem. The winter months have come, my vehicle; He started to stop at the lights, at low speeds, in the bumps and when he was driving with high performance, when he was slow.
I took them to several companies in Kahramanmaraş, all of them said that the chronic problem throttle will be cleaned, I had it cleaned, but it started again soon. When I asked the companies, they started talking about each other's workmanship, they said he couldn't, however, the friend completely poured a cleaning spray in front of my eyes and cleaned and checked all the sockets around the throttle. I have also maintained the vehicle in the same place and replaced all filters, oil and spark plugs, especially by providing the original .
During a period when the weather was extremely cold, I did not drive the car for 4-5 days, when I wanted to use the car worked with an extremely big jerk, wherever I knew all the screws were shaken, when I called the caring friend, "it is caused by the coil, stop, continue gas until it returns to normal. he will recover, "he said, and it was as he said, and this problem happened twice over the winter, I solved it in the same way.
I am sincere because I have gone many times, that I have to leave the vehicle for 1-2 days to himself, that he does not know exactly the question, he will find it by testing from cheap to expensive, He said that he could solve the problem between 50 and 800 TL. The weather is getting hot now and there is no problem.
Why do you think the problem is caused? I do not want to ignore that the weather got hot. have a nice day.
