stopping when lifting the vehicle
08.05.2020 14:16 # 1
muhlisoz
Hello friends, I have been actively driving since 2006. I have used cars like c4, golf, megane before. About a month ago, I bought a 2005 model 206 xt. Wall To avoid stopping on the ramp, load the gas well and shout the vehicle
There is no problem when it is lifted (not a normal ramp, not a ramp). At first I thought that I was a novice in the car, but I still have the same problem for a month. I tested the clutch in his vehicle, it is quite soft, mine is much harder than the 206's clutch is hard or my vehicle's clutch is hard and the pointer is working at idle as in the picture
let's 2010-06-11 20:52:38
08.05.2020 14:16 # 2
bulent 77
Clutch may be missing, idling is normal.
08.05.2020 14:16 # 3
muhlisoz
They said to the service while the car was taking 108 thousand cars, they said there was no problem
08.05.2020 14:16 # 4
okankrgz
idling seems normal, check clutch
08.05.2020 14:16 # 5
erkan samur
what version of the vehicle's injection computer is at an authorized service is 80% improved
08.05.2020 14:16 # 6
EminONAL
I think the clutch is more likely before injection, because idling is normal.
08.05.2020 14:16 # 7
BAHTIYAR
clutch pressure can also be from the lining pad was over in my old car, if the clutch grasps from above, this could be a problem if the car is shouting
08.05.2020 14:16 # 8
muhlisoz
When I put the vehicle into gear, Debriya said "Don't press it until the end".
