|   | Stopping problem when pressing clutch |
| 08.05.2020 21:25 | # 1 |
|  Pegoutmete | |
| 08.05.2020 21:25 | # 2 |
|  omerb | |
First of all, welcome.   Please do not mix the throttle with the idler motor. The throttle is closed when the vehicle is idling. Idling engine meets the air required for the vehicle's operation. The throttle starts working when you press the gas or move. As far as I can see, you have a motorized throttle in your vehicle. If I'm wrong please fix it.   The biggest problem of motorized throttle is adaptation.   Because the engine gives the gas level according to the reaction on your accelerator. This may be the reason why it does not stop when you press the gas. The idling motor does not engage when the vehicle is moving, when the gear is neutral or the clutch is depressed. It is activated when the vehicle stops. So your problem looks like this. First, get your car connected to the device. Look at the error codes. Then have the throttle adaptation done. Tell us the result, please. See you  | |
| 08.05.2020 21:25 | # 3 |
|  Pegoutmete | |
thank you my work will make a return with the result   Is there any possibility of being from a map sensor?  | |
| 08.05.2020 21:25 | # 4 |
|  omerb | |
there are many reasons. You need to learn the error code
| 08.05.2020 21:25 | # 5 |
|  ismailkaya | |
It is caused by the upper and lower oxygen sensors, while the vehicle is idling in gasoline, its lamps are turned on. After the last stage, open the sensor plugs, then switch the vehicle to gas and when working at idle, open the headlights, turn off the heating, stop the vehicle, stop the car without plugging the plugs you removed.
| 08.05.2020 21:25 | # 6 |
|  Yasam79 | |
I had the same problem today, the car stopped 3-4 times in the red light. Let's see I will show it to the master tomorrow.
| 08.05.2020 21:25 | # 7 |
|  Pegoutmete | |
where exactly are these sensors
| 08.05.2020 21:25 | # 8 |
|  Pegoutmete | |
[QUOTE = Yasam79] I had the same problem today, the car stopped 3-4 times in the red light. Let's see I will show it to the master tomorrow. [/ QUOTE] let's pass together, let me know about the result, if you can solve it, I'll tell you
| 08.05.2020 21:25 | # 9 |
|  Yasam79 | |
Okay, let's communicate.
| 08.05.2020 21:25 | # 10 |
|  ismailkaya | |
I'm talking about the sensors in the exhaust catalyst top and bottom sensors
| 08.05.2020 21:25 | # 11 |
|  Pegoutmete | |
friends, thank you very much I changed the map sensor on the vehicle and the problem has been solved it doesn't stop for a long time
| 08.05.2020 21:25 | # 12 |
|  ismailkaya | |
Unfortunately it will stop again.
| 08.05.2020 21:25 | # 13 |
|  Pegoutmete | |
why teacher
| 08.05.2020 21:25 | # 14 |
|  Pegoutmete | |
[QUOTE = ismailkaya] Unfortunately it will stop again. [/ QUOTE]   Why is that  | |
| 08.05.2020 21:25 | # 15 |
|  ismailkaya | |
The map sensor controls the pressure in the manifold and regulates the air fuel ignition system. If the map is malfunctioning, the vehicle will run abnormally or it will run as rich as air fuel. The tree will accelerate suddenly. But your vehicle is working normally, so your map sensor is solid and your problem is just to stop when you press the clutch.
| 05.08.2020 13:38 | # 16 |
|  Muco123 | |
I also have 1.4 hdi, my car stops when I start the clutch and slows down, but there is no problem when I go normally, when I stop and start it, the engine malfunction lamp lights up when it cools down a bit, the lamp ends when I heat up and press the clutch, a different sound from the engine comes to normal
| 05.08.2020 13:41 | # 17 |
|  Yasam79 | |
My friends, the whole problem is out of the brain of the vehicle. I changed the brain, all the problems were solved. Neither the fault lamp nor the stop is very good right now my vehicle.
| 05.08.2020 16:17 | # 18 |
|  ismailkaya | |
Unfortunately, you will encounter the same problems again, I hope your problem is solved.
| 05.08.2020 16:20 | # 19 |
|  ismailkaya | |
I think the brain has not changed.
| 05.08.2020 16:25 | # 20 |
|  Yasam79 | |
The vehicle was built in importance 9 brains were tested and only one got hold. Even my non-working air conditioner started working. It's been 2 months, there is no problem with my car.
