Stopping on the go emergency help
08.05.2020 20:01 # 1
Ali2627
First of all hello to everyone.
No 1.4 lpg gasoline in my vehicle while the speed (km) quadrant is going to zero and the lights are gone when the clutch furnace is stopped, I wonder if there is an idea or someone who has an idea. Ali2627 2016-11-10 10:49:30
08.05.2020 20:01 # 2
First of all, welcome to Ali. When it comes to the problem, the vehicle is diesel - if I do not have gasoline, this will be my priority question. lpg is the problem most likely lpg related. if not, throttle idle sensor plug and coil should be checked. diesel, injectors, diesel filter and pump control.
08.05.2020 20:01 # 3
Ali2627
We found the LPG, no gasoline
08.05.2020 20:01 # 4
then my teacher throttle - idling sensor - have the coil and spark plugs checked.
08.05.2020 20:01 # 5
fætih
Is there shaking shake at idle. just idling.
08.05.2020 20:01 # 6
samet206
It could be from the battery, when the battery was exhausted, we started with a few reinforcements.
08.05.2020 20:01 # 7
Ali2627
We solved the problem of the vehicle, thanks to the industrial masters, went to the highly knowledgeable biker, sent it to the electrician, went to the electronicsman, said to him, we went to the electrician again, this problem was said to be found, he said it was from the engine. There is such a thing that I can not peel off. Even if the word is full, the service is very expensive, you are right, but there is interest. I was angry last km on the way to the dust, he might have something in his mind. I mean, the car did not work, the car is not working. I tried to install a new one. I got out of the test. The car did not do anything like that. Do not go to the industry and eat the head.
08.05.2020 20:01 # 8
samet206
If it is resolved, get past. The situation has nothing to do with the same city everywhere.
08.05.2020 20:01 # 9
Mesut48
I am glad that the problem has been solved, get well soon
I just did not understand the km sensor, did you mean idling sensor?
