stopping at the first run
08.05.2020 17:24 # 1
seyyah
Friends
After waiting for a certain period of time before my car starts working, it stops at the first run and stops within 1 second, it does not do the same problem when the car is hot.
When I press the gas & nbsp; without stopping, it continues to stop and work in & nbsp;.
08.05.2020 17:24 # 2
NightKiss
Did you drain the catalytic?
08.05.2020 17:24 # 3
seyyah
I did not empty anything
08.05.2020 17:24 # 4
ahmet_bjk
Has a process been applied to the diesel pump?
08.05.2020 17:24 # 5
seyyah
no it just stopped
08.05.2020 17:24 # 6
_ali_
If there is little gas left in the LPG and gas tank, take some fresh gasoline and take a look.
08.05.2020 17:24 # 7
seyyah
my car is diesel
08.05.2020 17:24 # 8
plawert
There may be a problem with the auto choke because you state that the vehicle does not start after waiting, so there is a problem with the air-fuel mixture ratio when the engine is cold.
08.05.2020 17:24 # 9
seyyah
Do you think there might be a problem with diesel hoses?
08.05.2020 17:24 # 10
rockwaryumm
[QUOTE = plawert] auto choke may be a problem because you state that the vehicle does not work after waiting, so there is a problem with the air-fuel mixture ratio when the engine is cold [/ QUOTE]
It came to me like a choke when it was cold.
08.05.2020 17:24 # 11
baroff
What did my car say to the diesel? Glow plug is on diesel vehicles.
08.05.2020 17:24 # 12
_semihk_
it happens from the cancellation of the floor. most likely played in yours ...
If your diesel filter does not light up, of course.
08.05.2020 17:24 # 13
emin15
the fuel line is making air check the fuel pipes, especially the pipes under the air filter
