Stopping and not working as usual while on LPG
16.11.2025 23:42 # 1
BarlasEmirhan
First of all, hello everyone, my vehicle is 106 1998 model xs package 1.6 8v 5 door manual. The crankshaft sensor, LPG injectors, LPG regulator and oxygen sensor in my vehicle have been changed. The problems I have experienced are as follows: https://static.cloudflareinsights.com/beacon.min.js/vcd15cbe7772f49c399c6a5babf22c1241717689176015" integrity="sha512-ZpsOmlRQV6y907TI0dKBHq9Md29nnaEIPlkf84rnaERnq6zvWvPUqr2ft8M1aS28oN72PdrCzSjY4U6VaAw1EQ==" data-cf-beacon="{"version":"2024.11.0","token":"7110ac1acf9c43d28f8a98a4df569c35","r":1,"server_timing":{"name":{"cfCacheStatus":true,"cfEdge":true,"cfExtPri":true,"cfL4":true,"cfOrigin":true,"cfSpeedBrain":true},"location_startswith":null}}" crossorigin="anonymous">1- When the engine is cold, it stalls when switching to LPG. When I press the clutch until it warms up in LPG, it stalls (Switching temperature is 40 degrees). 2- The engine idles when I start, which is exactly the same problem that started yesterday before the crank sensor was changed. I am looking for a solution to these problems. I am fed up with this vehicle malfunctioning to this extent, please help. It is a clean example, original filter box etc. everything is present and I bought it in June with 197500 km, when I bought it it had 191250 km, and these faults were not present.
17.11.2025 00:15 # 2
BarlasEmirhan
+ It shakes when switching to LPG. It stutters just when it switches to LPG, which it did before the LPG regulator changed. https://static.cloudflareinsights.com/beacon.min.js/vcd15cbe7772f49c399c6a5babf22c1241717689176015" integrity="sha512-ZpsOmlRQV6y907TI0dKBHq9Md29nnaEIPlkf84rnaERnq6zvWvPUqr2ft8M1aS28oN72PdrCzSjY4U6VaAw1EQ==" data-cf-beacon="{"version":"2024.11.0","token":"7110ac1acf9c43d28f8a98a4df569c35","r":1,"server_timing":{"name":{"cfCache Status":true,"cfEdge":true,"cfExtPri":true,"cfL4":true,"cfOrigin":true,"cfSpeedBrain":true},"location_startswith":null}}" crossorigin="anonymous">
