STOPPING (307)
08.05.2020 15:10 # 1
okanisilak
Hello friends.
I have a 2002 model 1.6 peugeot 307 vehicle. atiker lpg attached.
idling and some power was lost in my vehicle today.
both gasoline and lpg have the same problem, but not continuous.
for example, it stops when I press the clutch to downshift.
sometimes it works stably at idle for minutes. then it starts kicking
and it stops.
the malfunction lamp never lit.
I have a problem with these friends. what could be the reason for you? I would be glad if you help.
08.05.2020 15:10 # 2
CihanHancerli
My friend keep on topic constantly. If anyone knows, he sees an answer
08.05.2020 15:10 # 3
FTH
[QUOTE = CihanHançerli] My friend, don't keep on topics. If anyone knows, he sees the answer and writes [/ QUOTE]
Thumbs Up
The other topic has been deleted. If anyone knows what the world says, you will get an answer.
Pleasant forums
FTH 2011-03-15 19:32:06
08.05.2020 15:10 # 4
okanisilak
I do not always have a subject, I think there was a problem with the computer.
08.05.2020 15:10 # 5
sniperElite
directly change the thermostat, it turns on early, the second one is the crank speed sensor, take a look at it, the sensor does not come out on the computer.
08.05.2020 15:10 # 6
[QUOTE = sniperElite] change the direct thermostat is opening early, the second one has a crank speed sensor, take a look at it, the sensor does not come out on the computer. [/ QUOTE]
Dear brother, I can not attend what he says.
I think the engine stop with a thermostat has nothing to do with it. We went to the test with my brother's 307 vehicle in the past. but there was no stopping. more precisely, it is not related to the engine stopping the heat. Or how will the engine run when cold ...
The crank stop sensor, which I can not say about it, may be from it. however, the connection to the crank sensor may not be made for each RPG vehicle. For example, I have a bobbin connection in my vehicle. No connection to the speed sensor. so it is not necessary to take it from the speed sensor ... keep this in mind ...
the cecol 2011-03-15 22:07:57
08.05.2020 15:10 # 7
okanisilak
I couldn't understand the relevance of the thermostat.
I don't think it will happen from him.
The strongest possibility I can think of is the ignition coil.
what do you think is likely to be from the coil?
08.05.2020 15:10 # 8
furkan
egr valve may be clogged
08.05.2020 15:10 # 9
okanisilak
But wouldn't any of these reasons cause the malfunction lamp to come on?
08.05.2020 15:10 # 10
furkan
No egr valve, as you say, idle it, search it from Google
08.05.2020 15:10 # 11
kaan__
I do not know whether this setting is complete or not. For now, you can check the other parts after trying to throw a charge and I also saw friends who have problems with stopping the form.
this is my personal opinion, don't get me wrong Handshake
08.05.2020 15:10 # 12
kaan__
Sorry, I was so embarrassed that I had the same problem with gasoline. Pinch ... as the furkan brother says, it is useful to clean the throat butterfly by looking at the egr valve
08.05.2020 15:10 # 13
metin
[QUOTE = cecoli] [QUOTE = sniperElite] change the thermostat directly. The second one is the crank speed sensor. Take a look at it. The sensor does not come out on the computer. It knows the lpg ecu water is circulating from there, but definitely change the thermostat. [/ QUOTE]
neither opened early, the brother never closed (: never stopped despite it. has nothing to do with the thermostat.
08.05.2020 15:10 # 14
serkan106XR
Did you notice that this is like idling sensor malfunction?
08.05.2020 15:10 # 15
furkan
Idle malfunction happens in every vehicle my opel corsada and astrada happened in the same place reno clioda was in ki saphiada it was also in every car I used but the pejo also did not happen for some reason that the pejo is more robust eg the valve can be a problem in every car, the problem is removed if it is cleaned with thinner, the problem is removed. Not that I know, but it happened to me a lot
08.05.2020 15:10 # 16
okanisilak
thanks for the ideas you gave friends.
oddly enough when the engine is cold.
happens when the engine starts to warm up.
and not continuous, just a few minutes it works normally, stopping and stopping.
and there is a smell of fuel on the move.
Do you think it is normal for the malfunction lamp to not light up in such a situation?
08.05.2020 15:10 # 17
okanisilak
friends today i went to peugeot authorized service.
The problem was that the throat butterfly got dirty.
they made a quick cleaning with lining spray,
my problem has gone on a large scale, but sometimes it stops again, although very little.
Is it possible to remove the butterfly and idle sensor and clean them in detail?
08.05.2020 15:10 # 18
[QUOTE = okanisilak] friends I went to peugeot authorized service today.
It is possible. I put here pictures before and after the cleaning I found from another forum. They were cleaned with air thinner or gasoline and dried with air. You can also clean with sprays.
Note: I think this throat butterfly belongs to another brand vehicle but its tip is up and down.
Pre:
Post:
Source: http: My //www.skodam.co
Koliva 2011-03-18 20:36:31
08.05.2020 15:10 # 19
So I found a video:
[TUBE] G-mwd5vjkt8 [/ TUBE]
08.05.2020 15:10 # 20
okanisilak
Thanks.
Page : / 2
