Stop when the air conditioner turns on
08.05.2020 18:34 # 1
Mesut48
Hello friends,
My car 2004 model 206 Xt car is lpgli and 107 thousand km.
My problem stops when I open the air conditioner and press the clutch while going on the road.
With the air conditioner turned on, it seems like the cycle is fluctuating.
I would be glad if he / she writes what happened before or who knows the solution.
08.05.2020 18:34 # 2
Serkan
Does it do it on gas? If it does not work in gasoline, it is in the lpg setting, the vehicle may remain in idle speed, try to calibrate while the air conditioner is on.
08.05.2020 18:34 # 3
korkusuz202
Check the fuel pump, korkusuz202 2014-05-24 11:26:12
08.05.2020 18:34 # 4
Turgay_66
the idle speed is low, or there is a problem with the compressor.
08.05.2020 18:34 # 5
Mesut48
I have never tried it on gasoline experience,
thanks friends for comments.
08.05.2020 18:34 # 6
captain_b5
Idling is very low.
08.05.2020 18:34 # 7
muro_60
If the experiment does not do the same, if the engine does not fail, make an LPG adjustment.
