Stop When Stop Stop ....
08.05.2020 16:17 # 1
muntehaozen
Greetings, when I start the car 3 times with the stop lamp, I hear the sound of the dice. muntehaozen 2011-10-27 12:19:09
08.05.2020 16:17 # 2
metin
Which lamp comes on 3 times with the stop lamp?
08.05.2020 16:17 # 3
berk2309
when the battery came out of charge yesterday & nbsp; my dynamism was broken, what happened was the battery & nbsp;
08.05.2020 16:17 # 4
If the vehicle does not have difficulties when starting, there is no problem with the battery.
08.05.2020 16:17 # 5
muntehaozen
The battery was reset and it did not work for a period of time.
08.05.2020 16:17 # 6
muntehaozen
[QUOTE = text]
Which lamp is on with the stop lamp 3 times? and 3 times & nbsp; the stop lamp is flashing on the display with these 3 digits.
muntehaozen 2011-10-27 14:07:31
08.05.2020 16:18 # 7
It happened to me last time, looking at it with a little care, you will know that it is from water, tap ap kuulınt ıl pıliz!
08.05.2020 16:18 # 8
muntehaozen
[QUOTE = mustafa_uslu] Just happened to me, when you take a careful look, you realize that you are from the water, tap ap kuulınt levıl pıliz! : ([/ QUOTE]
well, is this engine water when I say this water level?
08.05.2020 16:18 # 9
Muhammet CAKIR
Does the vehicle stop? If there is such a thing, it may be giving immolizer error. I just said my opinion :)
08.05.2020 16:18 # 10
[QUOTE = muntehaozen] [QUOTE = mustafa_uslu] Just happened to me, when you look at it a little carefully, you will know that it is from the water, tap ap kuulınt pıliz! I am sorry to take the sin of the man: ([/ QUOTE]
but when I say this water level, is it engine water? + me & nbsp; "tap ap kuulınt levıl pıliz" does not give such an error:) [/ QUOTE]
I didn't give it to me in the beginning, just a few days, it just sounds after the first study, then it is silent and it doesn't have a problem when it is hot, the other one keeps singing but I waited for a few more days. Then he gave the warning of engine coolant / water (also called antifreeze) and then I received a tap ap built-in level warning, then I applied the tap and nothing was left: D & nbsp;
08.05.2020 16:18 # 11
eserxxx
I have a problem with the bear, but the stop lamp does not light up, only 3 times it sounds. As you said, I look at the engine coolant, there is no missing. I said I can not do it, I showed it to the master, he said it is not missing. But I still hear three times at the first acceleration when the engine is cold. & Nbsp;
08.05.2020 16:18 # 12
Try this, look at the level without running in the morning, run to the level, go your way, then look again without stopping. I do not know if it should be, but I do not know if the vehicle is increasing or decreasing the amount of fluid in different situations, whether it is expansion with temperature. & Nbsp;
08.05.2020 16:18 # 13
my.ozkara
the same happened to me, neither water loss nor expansion. The problem is entirely caused by the sender below the water level. When the water level is full, there is no warning warning when the sender is removed. :D
08.05.2020 16:18 # 14
sedat23
The same thing happened in me 2 years ago, if I am not mistaken, there was a problem with the dynamos, I changed it, I think it went to a service.
08.05.2020 16:18 # 15
Ucyuzalti
The LPG started in me, it was going to stop, the weather got cold, the stops started.
08.05.2020 16:18 # 16
eray307
[QUOTE = my.ozkara] the same thing happened to me. Neither water loss nor expansion. The problem is entirely caused by the sender below the water level. When the water level is full, there is no warning warning when the sender is removed. : D [/ QUOTE]
can you talk about the exact location of this client?
