Stop Warning Light
08.05.2020 16:56 # 1
phoenix.1905
Guys, I traveled about 250 km with my 306 vehicles today. During this journey, the stop warning light of my vehicle started to light up from time to time. I looked at the temperature is normal, no other malfunction indication and abnormal condition. However, I thought about the tachometer sometime, but when I said at 3000, 2000, I said that it has nothing to do with the cycle. Stop warning light does not blink constantly, it turns on for 1-2 seconds. Then it burns the same way again after 5 minutes during the journey. I stopped the car, I waited for 15 minutes and I continued my way, I had 1 hour left and it flashed once. & nbsp;
So why could this Stop warning light turn on? & nbsp;
Note: The pressure of this warning light Does it have anything to do with pads?
& nbsp; (My average speed is 100 km / h)
08.05.2020 16:56 # 2
pug206
get the finished master who started the press.
08.05.2020 16:56 # 3
phoenix.1905
Handbrake wire & nbsp; changed 1 month ago. So is this print costly? In addition, they say something for pressure pads. I tried keeping it well. & Nbsp;
08.05.2020 16:56 # 4
volkan22
my brother meant that the stop light faulty fan motor & nbsp; was burning in my car intermittently. Think of my vehicle
my fan motor has changed, it has also changed. Also, if the light freezes unevenly, it turns on, when the light comes on, I feel like the fans will come back to me. div>
and fan make 3 wars on them. This stop light is definitely related to the cooling of the vehicle & nbsp; 3 & nbsp; musur war & nbsp; 1.ecu 2. fans 3. indicator & nbsp; I know it is brown fans & nbsp;
when that light comes on, your fans will freeze like crazy & nbsp; my fan motor was not distilled, I changed it, you forget about the press pad, I am 100% sure that it is brothers. / edited>
08.05.2020 16:56 # 5
volkan22
http://forum.peugeotturkey.com/forum_posts.asp?TID=24163
if you have 100% knowledge of your english Let's not misinform anyone ...
volkan22 2012-07-31 00:42:58
08.05.2020 16:56 # 6
berk2309
If the tacho clock drops and gets up again, it works if the conjunctor in the charging dynamo is wrong and the wrong charge can happen.
08.05.2020 16:56 # 7
volkan22
:) my burning & nbsp; stop light fans were freezing like crazy. & Nbsp; I don't need to change the solenoids, I don't know what napacam & nbsp; occasionally knocks sports and snow lights sometimes: S auto car
08.05.2020 16:56 # 8
phoenix.1905
[QUOTE = volkan22] my brother, that stop light is the fan motor with faulty light & nbsp; my car was on fire from time to time. start my car :) I think my auto vehicle has changed
my fan motor has been displaced, it has also changed.
and fan do 3 wars on them. This stop light is definitely related to the cooling of your vehicle & nbsp; 3 & nbsp; musur war & nbsp; 1.ecu 2. fans 3. indicator & nbsp; I know it is brown fans & nbsp;
when that light comes on, your fans will freeze like crazy & nbsp; my fan motor was not distracted, I changed it, you forget about the press pad, I am 100% sure, brother. & nbsp; Then the heat & nbsp; stay on the fans, unless they are based on red. I think it doesn't seem to do much. Because it adjusts the heat well, the fans made a maximum of 95 degrees. The room is on a slope. & Nbsp;
08.05.2020 16:56 # 9
HiLaS
hi
When the 1st car runs, look at the fans immediately if it works
If the 2nd move does not exceed 70-80
problem I had the same problem in the fan brain
< div>
price 190 tl & nbsp;
the market is also 70 TL
Take a look at the left side under the mudguards, oxidized.
I I removed it, looked, oxidized, cleaned, put it, it improved.
< div> make it easy
08.05.2020 16:56 # 10
mehmet_2
The same problem in me was caused by the temperature of the temperature sensor. I pulled it out and I blew it and it wasn't any more
08.05.2020 16:56 # 11
206206
last year on me & nbsp; burnt stop written & nbsp; lamps & nbsp; brake pad
08.05.2020 16:56 # 12
barutcu17
friends taillight event happened to me today i started the car burned burned after 10 seconds then it was lit up again after two minutes then burned again now i will be happy if you explain if i can tell you from brake pad or pressure pad or from fan to repairer
08.05.2020 16:56 # 13
volkan22
When the stop alert & nbsp; is burning, I can say that the fans are freezing fast. & nbsp; check the brake oil. If it does not stop, it says if it is lit continuously, connect it to the computer.
08.05.2020 16:56 # 14
silivriserdar
I have the same car in Bend, I follow the matter. I would be glad if you share the result with us here. At least, we don't bother if it happens to us.
08.05.2020 16:56 # 15
emin15
[QUOTE = HiLaS] hi
price 190 tl & nbsp ;
Take a look at the left side under the mudguards, oxidized. < / b>
I disassembled myself, looked, oxidized, cleaned, put it fixed.
make it easy
Your friend fan brain as said Sockets are oxidized and sometimes enter inside
08.05.2020 16:56 # 16
salutary
[QUOTE = phoenix.1905] Guys, I have traveled about 250 km with my 306 vehicles today. During this journey, the stop warning light of my vehicle started to light up from time to time. I looked at the temperature is normal, no other malfunction indication and abnormal condition. However, I thought about the tachometer sometime, but when I said at 3000, 2000, I said that it has nothing to do with the cycle. Stop warning light does not blink constantly, it turns on for 1-2 seconds. Then it burns the same way again after 5 minutes during the journey. I stopped the car, I waited for 15 minutes and I continued my way, I had 1 hour left and it flashed once. & nbsp;
Hello friends. I had the same problem for about 3-4 months. The master I had my car maintained could not find the problem. "I have to get all the cables over," said the auto electrician. I also couldn't trust it and found a good motor master with friendly advice. The problem is the recirculation bearing & nbsp; it was largely due to the end of its life. I was very surprised when I saw the gears. Trigeri completely changed the circulation. Stop warning lamp never lit again. My car's voice, traction has changed. I called the master, thank you. Now I will have the maintenance done to him :)
08.05.2020 16:56 # 17
Yusuf cakmak
is there someone to help me? 307 1.6 diesel problem in my car when i turn on the headlights when i turn the lights for two km, the lamp is on, the car slows down, I change the gears, it continues to eat gas again
08.05.2020 16:56 # 18
[QUOTE = Yusuf Çakmak] Is there anyone to help me in my car? / QUOTE]
first of all welcome to us. I think the vehicle is making a short circuit and I think it should be connected to a computer and look at the fault code. There could be many reasons for this. & Nbsp;
1-motor ecu (brain) sockets & nbsp;
2-fuse box
< div> 3-bsi
4-com2000 headlight turn signal lever etc.
08.05.2020 16:56 # 19
m_margun
friends, I went to the industry today while I was on the move, because the brake fluid was low due to the shortage of stop light flashing. the master added light on it never burned again
