Stop stopping idling at 206 LPG
08.05.2020 19:32 # 1
Stive
Hello everyone, good forums. 206 2005 1.4 xline
No problem when the car is on the road.
When I get the light, I press the clutch stops. I'm going to make a U-turn, I am braking the clutch 3 stops for 4 seconds. Help me with knowledge experience. Stiva 2015-12-13 01:21:29
08.05.2020 19:32 # 2
Stive
They said idle engine or butterfly or something, I cleaned it with a spray, it looks normal.
08.05.2020 19:32 # 3
Teacher, then, if there is no problem in the regulator and system related to the lpg settings, ask the vehicle to be adjusted while the lpg setting is in motion.
08.05.2020 19:32 # 4
ssakyel
Sir, I had the same problem in my UNO model vehicle I used before. It was idle, it stopped when the red light stopped or something. It was very annoying. Then I did research. Throttle adjustment, throat butterfly, idling engine are some of the reasons for this malfunction. Mine was idling engine out and changed and dried. If you want to have a control,
08.05.2020 19:32 # 5
IbRahiM_quRcaN
My brother, first of all, my clio 3 also had that problem. Generally it is due to the fuel you use. If the fuel value you get is low, its firing will be slow and sore. This may cause the car to slow down and stop the fuel.
