Stop problem (Solved) |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 206+ | |
| 08.05.2020 19:09 | # 1 |
| 08.05.2020 19:09 | # 2 |
Hi, my brother, there may be a short circuit in the car, obviously, there was toyota in me as an electrical distress when the air conditioner was turned off when the air conditioner turned off when it was 1000 cycles when the air conditioner was turned off. In case you have a new tape recorder, he may be doing it if there is an error in the connection, I just guess, but I don't know how to solve it.
| 08.05.2020 19:09 | # 3 |
[QUOTE] or a short circuit battery, whatever the tape is, you can do it if there is an error in the connection, I can only guess it, but I don't know how to solve it. In my case we have improved the left setting, it was improved but it was not permanent [/ QUOTE] yes in kind problems. thanks I just changed the battery |
| 08.05.2020 19:09 | # 4 |
Google is looking for the problem of idling, I get out of the coil :) There is also a tremor problem when idling, gas does not matter
| 08.05.2020 19:09 | # 5 |
I think there are many reasons for the problem of idling, does the malfunction lamp light up or something
| 08.05.2020 19:09 | # 6 |
Normally, if there is no speed playing, if you turn on additional tools like air conditioner, if the speed drops excessively, there is probably an electrical problem. You just replaced the battery. Have the bidet charger checked.
| 08.05.2020 19:09 | # 7 |
I've been having this problem for a while. Coil and injectors have been replaced with the original, but the problem has not passed. We replaced the idling engine and it wasn't over yet. We removed the idle engine and installed the old one. I noticed recently that the car is making this fault when it rains. The PP200 had already shown an electrical failure. Now I am looking for the place that gets wet in the rain and causes this problem. I saw the driver of the steering hisrolic engine somewhat around. I think you should follow this direction.
